Hey everyone; So I went to try Nehrim for the first time today and was saddened that it uses the same config files as Oblivion! (specifically Oblivion.ini and Plugins.txt)
This annoyed me immensely, so I fixed it. Attached is a small patch created using XDelta3 (http://code.google.com/p/xdelta/)
EDIT: GO TO BOTTOM
EDIT: GO TO BOTTOM
EDIT: GO TO BOTTOM
OLD STUFF EDIT3: I updated the patches so instead of changing the files that are created they simply change the directories.
NehrimFE will be used instead of Oblivion (where applicable in relation to the directories).
If you wish to use OBSE with this patch you need to open up the source code and add the crc 'A905C71C' to the accepted list for 1.2.0.416, recompiling afterwards.
In order to use the patches open up cmd and do
EDIT: GO TO BOTTOM
EDIT: GO TO BOTTOM
EDIT: GO TO BOTTOM
Code Select all
xdelta3 -d -s oblivion.ori.exe nehrim-oblivion.exe.vcdiff oblivion.exe
xdelta3 -d -s NehrimLauncher.ori.exe NehrimLauncher.exe.vcdiff NehrimLauncher.exeAttachments
NehrimPatches.zip
Nehrim XDelta3 diff. Patches, see thread.
(539 Bytes) Downloaded 213 times
Hey mate,
Applied the patches, and then when I open the Launcher and click Data Files it throws up an error.
If I ignore the error it shows 0 data files listed, did I do something wrong or am I forgetting to do somethinhg, or is it just not working with the latest version?
