6 posts • Page 1 of 1
Diese MOD lässt den Spieler und NPCs bestimmte Posen einnehmen.
Quelle: TES-Nexus
Readme
Pose Thumbnail Poses 1.1
by Selene310187 aka darklady310187
- Poses made by Lera and Pizz -
- Converted to Nehrim by Niwo -
Version: 1.1
Oblivion version: 1.2.0416
Nehrim Version: I don't know. But latest is always the best. ;)
Description:
This pack contains 112 poses from the Pose Thumbnail:
http://209.85.135.104/translate_c?hl=de ... tml%23more
(translated version; scroll down to the clickable screens)
A script adds an animation ball called "Pose Thumbnail Crystal" and a spell ("Director's Touch - Pose Thumbnail")
to your inventory.
Playing an animation:
Equip the "Pose Thumbnail Crystal", close your inventory and choose an animation, or put the ball on a hotkey and
then choose the animation. Click "Reset Animation" and your character becomes normal again.
Use the spell on NPCs to make them perform the poses.
Issue:
You may hang a bit in mid air at some poses. So use the console command tcl (typing tcl again makes your character normal), the mouse and the
buttons WASD to move your character to the right position. The same is true of pair poses. Tip:
Use the console command tai to toggle the AI off (the NPC will stay on the same position the whole time). Type
tai again to toggle the AI on. Other useful commands are tm (toggle menu off) and tfc (free camera).
Version history:
1.0
Initial release with 103 poses
1.1
- 9 new poses are added
- a wrong file path is fixed
- improvement of the menu
How to install?:
If you downloaded version 1.0 before, please delete it. Extract the archiv of version 1.1 in any folder and copy
the "Pose Thumbnail Poses 1.1".esp and "Pose Thumbnail Poses 1.1".bsa in your Nehrim Data folder.
Activate the "Pose Thumbnail Poses 1.1".esp and play Nehrim.
Credits:
My special thanks goes to Lera and Pizz who are the creators of the poses.
Thanks to Bethesda for this super game Oblivion!
Pose Thumbnail Poses 1.1.7z
(1.46 MiB) Downloaded 571 times
Meine Empfehlun ist CTAddPose, das sind 3 Module mit einer Menge an kompatiblen Posen. Allerdings sollte man die nur aktivieren wenn man fotografieren will, es kommt sonst im Gameplay zu Distanzfehler (einsacken im Boden etc).
Gibt´s CTAddPose etwa schon für Nehrim? Wenn ja, bitte ich dich ganz lieb um den download-link :).
[threadnekromantie]Hat jemand zufällig die Files dieser Mod noch irgendwo rumliegen und wäre so freundlich, sie mir rüberzuschicken bzw sie zu re-uploaden? Ich bin leider zu blöd, die Oblivion-Mod zu konvertieren und die Nehrim-Version des Ganzen ist nirgendwo mehr zu finden, alle existenten Downloadlinks sind offline :( Mein Retter bekommt auch zehn virtuelle Kekse und ein Quietscheentchen *Hundeaugen mach* [/threadnekromantie]
Ich hab die Mod bei meiner alten Nehrim-Installation drin, allerdings scheinbar nicht mehr als .zip... Mal sehen, ob ich die Dateien auch so zusammegesucht bekomme :P (oder reicht die .esp)?
Edit: Hier die .bsa und .esp. Ich weiß nicht, ob das alle Dateien sind (in der Nehriminstallation habe ich 50+ Mods drin...), aber versuch es mal: http://www.file-upload.net/download-789 ... 1.zip.html
Ach, und file-upload (der Hoster) behält die Dateien meiner Erfahrung nach nicht besonders lange. Dann sollte jemand die vielleicht noch woanders hochladen; ich habe leider nirgends einen Account.
Und wieder ist greenlight mein Held <3 Vielen Dank für die schnelle Antwort und den Upload, ich hab mir dazu einfach die Oblivion-Mod gezogen für die Texture & Mesh-Ordner, diese dann in den entsprechenden Nehrim-Pfad gepackt und deine .bsa und .esp dazu genommen. Funktioniert wunderbar! (=
Achja, nicht zu vergessen die 10 Kekse und natürlich das Quietscheentchen! :mrgreen:
LG,
Arthael
