When I started playing Nehrim, towards the beginning of the game, I had a glitch where I couldn't find Martin (I think that's his name). I finally found him off in the distance running against a rock, so this Isn't my problem, that was just the start of my troubles.
After he asked me to find some support beams, I easily found the shovels. After all, it was marked on my map. After the shovels, I went and talked to martin, or whatever his name is. He said "stay away from the gate." So now I was thinking i didn't do something right for the quest (which is still a possibility). Because of this, I decided to further raid the cave of everything I was able to pick up, just in case I missed something. Still, no luck. I FINALLY decided to look at a video walk through. When the person who made the walkthrough walked up to the gate after he got the shovels, mages attacked. The walkthrough was in German, so I had to clue what he was saying.
Did I miss something, or is my game just glitched?
Please help, for I was looking forward to Nehrim. Thanks, RAWR.
When I retrieved the shovels, and walked to the gate, the Mages attacked, so the shovels were never used. They are a quest item so they still remain in my inventory.
well yeah, but the mages DONT attack on my game. It's very frustrating...
Can you please upload your savegame?
Okay, here's the save. I tried just about everything, including experimenting with console (I didn't save after doing so), to fix it.
I think I'm probably going to have to start a new game, or reinstall it. So to avoid trouble, if anyone can diagnose the problem that would be excellent. I am using the steam version by the way.
Save 372 - Sam - Western Fold Valley (Level 1 to 7), Level 3, Playing Time 19.28.09.ess
(813.21 KiB) Downloaded 221 times
I have sent you a patch that should fix the bug. However, the mages are prone to running away, leading you into a killbox - try not to follow them but rather to run back into the direction of the mine (they will then follow YOU and you can fight them).
Alright, thanks so much. Hopefully there wont be ant more technical difficulties.
