Okay so, i found a key in a dungeon to zerobilion. Cleared it. Is there a quest tied to this area? If so without picking up the quest have i broken anything? Theres a door in the zerobilion dungeon that seems to be blocked off with a shield with a portal behind it, and i'm wondering if its blocked off because i haven't got the quest.
There is a starter quest that would lead you to the dungeon where you get the key, but it is entirely optional.
The part behind the portal is not finished yet and will be released in a patch, later.
Thanks!
Moreover, you can still do the quest if you have cleared Zerobilon.
Where we can get quest for Zerobilion? It's Optional??
Second - We can get wanted quest In all city or If we done one series of wanted quest we can get more? I kille mage necromancer and cant get more wanted quest from Giliad for example. I didnt tried in other cities.
You get the same wanted quests on any of the noticeboards. There are only about six or seven.
After the last bounty you will get an achivement, but the text is in german, something like bounty hunter achievement.
But where I can get quest for Zenobilion?
hehe i just got it by accident, on the road thats up the hill from the showgrounds, just go directly straight from the coach in the showground and up the hill you will find some chests and wagons on the road, open the chests and one of them will start the quest line, i don't want to say anymore because it will be a spolier.
Donkerman wrote:You get the same wanted quests on any of the noticeboards. There are only about six or seven.
thats not actually the last quest, its just the remaining quests haven't been translated yet so won't be available until after a patch.
Those wagons are near zenobilion??
