15 posts • Page 1 of 1
I used a clean install of Oblivion from Steam (deleted and redownloaded everything), and I only activated the three Nehrim files using the Steam game launcher. I launch the game and it works fine. I start a new game, and customize my character. However, once I click "Done" and confirm my race, the game crashes. Every single time.
This might be due to a file conflict, where the Steam version of Oblivion has a file in /Steam/steamapps/common/oblivion/Data/Music/Dungeon named 'Dungeon_01_v2.mp3', whereas Nehrim has a folder named 'Dungeon_01_v2.mp3', which contains the file 'Dungeon_01_v2.mp3'. My solution was to delete the Oblivion file, so there was no conflict.
Please help!
Bump. Can anyone help me?
More info:
Windows 7 x64
HD 5770
4GB RAM @ 1066
Phenom II X4 940 @ 3.5GHz
Biostar TA790GXE motherboard
Samsung Spinpoint F3
Oblivion GOTY Steam edition, fresh install.
I don't think Nehrim has a FOLDER named Dungeon_01_v2.mp3. Something must have gone wrong during your installation.
I wondered if my install wasn't corrupted, actually (it was the torrent version). So I went to filefront and downloaded that version. It's the same. Can anyone check on the existence of the folder?
I don't have such a folder in Data\Music. Where do you have it?
*Wherever you installed Nehrim*/Data/Music/Dungeon/Dungeon_01_v2.mp3/Dungeon_01_v2.mp3
The folder contains the file of the same name. I've tried deleting the folder and keeping the file, as well as keeping the folder and file. I installed Nehrim files on the desktop but I have UAC turned off, so it shouldn't make a difference anyways. I will check the sha1 and md5 sums when I get home, but I doubt that's the problem considering the fact that I've downloaded two installers that exhibit the same behavior. Then again, maybe the torrent version is messed up, and the Fileplanet version is just a rehost of the torrent version.
Excited to play once we figure out the problem :)
There is a /Data/Music/Dungeon/Dungeon_01_v2.mp3 in the German Nehrim Version.
It is a 2.452.585 Byte mp3 file, it is identical to the one in my Oblivion installation (UK GOTY).
Maybe the result of an Installer hickup?
Probably. The sha1sum of the english installer I have is be78743ad9391e3a741ced11a769afd2ee906aac
Can anyone confirm this as correct? If it is, we can start looking elsewhere. Hopefully the sha1sum is wrong, and it was just a bad version of the installer...
MD5 Sum: 2395ef942f7bc67be794f267604c3809
SHA1 Sum: be78743ad9391e3a741ced11a769afd2ee906aac
You have the right checksum.
You have proven that can use a checksum generator. ;)
Are you feeling lucky today? Then take a look at the "[WIP] Automated testing of your Nehrim installation" thread.
This might help to identify the problem and it was this thread was the final straw that ticked me so far off that I actually worked on a more automated solution to the problem. ;)
Oh, since you are using Steam the oblivon.exe and maybe some dll will have another checksum.
Okay, here's the errors I got:
C:\>fciv.exe -v -bp "C:\Program Files (x86)\Steam\steamapps\common\oblivion" -xm
l c:\nehrim_en_1075.xml
// File Checksum Integrity Verifier version 2.05.
Starting checksums verification : 09/20/2010 at 16h08'59
List of modified files:
Unable to Hash file Data\Music\Dungeon\Dungeon_01_v2.mp3\Dungeon_01_v2.mp3
        Error msg  : The system cannot find the path specified.
        Error code : 3
Data\Oblivion - Meshes.bsa
        Hash is         : cbfae6ff4cc15e8651a93da44eaae883
        It should be    : 284e8841d500e79b3eb395834c0a32e8
Data\Oblivion - Textures - Compressed.bsa
        Hash is         : e92f05e6a07c1b399b31b9c007255022
        It should be    : 575741a091d49b3e0fc7fdba1382a606
oblivion.exe
        Hash is         : 97c6700edadcfd407a0cc0c988c6b9e0
        It should be    : cdd2f0c5eff198d4f26b7b5b54ce4930
unins000.dat
        Hash is         : 82797b839a20916034865cf438d6f359
        It should be    : 140dac24bf09a1f5a4973257771bf1b0
End Verification : 09/20/2010 at 16h09'57
I had the same problem with that folder, so I just told it to delete the folder (didn't know what the hell else to do). One install earlier, I believe it did not include the folder (didn't ask me what to do with my copy), but I didn't get any useful statistics that time because the windows filenames are absolutely retarded.
I think it has something to do with either Windows 7, 64 bit, Steam, or a combination of the three. Any ideas?
EDIT: However, it looks like it wants the folder to be there, so I put the folder back. Here's the updated checksum:
C:\>fciv.exe -v -bp "c:\Program Files (x86)\Steam\steamapps\common\oblivion" -xm
Starting checksums verification : 09/20/2010 at 16h22'41
oblivion.exe
unins000.dat
End Verification : 09/20/2010 at 16h23'42
I'll take a closer look at the checksums later.
Seems I have a problem in the list. (the .mp3)
That oblivion.exe and unins000.dat are different is expected.
It would be really nice if another Steam User could post some checksums.
"Data\Music\Dungeon\Dungeon_01_v2.mp3\Dungeon_01_v2.mp3"
The file should be located in "Data\Music\Dungeon\Dungeon_01_v2.mp3"
This is an error in my and some other EN installations. Will investigate further... Seems like an installer problem.
"Data\Oblivion - Meshes.bsa"
EN and DE (patched to 1.0.7.5) have different files.
DE (patched to 1.0.7.5) MD5: 98657a85f6e3b6c5bff08db1a3e307d6
"Data\Oblivion - Textures - Compressed.bsa"
EN and DE (patched to 1.0.7.5) have the same files.
Has the Steam version a different file than the UK GOTY?
"\Program Files (x86)\"
Can be - No, almost always is - a problem because of UAC.
In this case because you (probably with admin rights) had to copy the Nehrim files which have different access than the Oblivion files and thus can be inaccessible to Oblivion.exe.
Can you "convince" Steam to install Oblivion somewhere else?
I'd have to move/reinstall about 150GB of files, and I don't know what else that would break. I have UAC turned off, though it might still affect the folders.
Ok, that would be a bit too much.
Can you find out which UAC permissions Oblivion files have, and then set them on the whole Oblivion folder including the Nehrim stuff?
Moving the Oblivion installation to another directory would probably be a problem with the Steam DRM.
I actually got that same error message when I installed. I just hit "ignore" and the game has, thus far, worked fine. (Just got out of the mine.)
