15 posts • Page 1 of 2
Hello, i got similiar issue, reinstall doesent help, i whitelisted everything, deleting inis also didnt work. This is the log from Skyrimredirector:
2022-10-03 17:48:21.475 [INFO ] Skyrim Redirector by Davipb started. github.com/Davipb/SkyrimRedirector
2022-10-03 17:48:21.475 [WARN ] Ini path 'C:\Users\Sledziu\Documents\My Games\Enderal\Enderal.ini' doesn't exist, trying to regenerate it
2022-10-03 17:48:21.475 [WARN ] Prefs Ini path 'C:\Users\Sledziu\Documents\My Games\Enderal\EnderalPrefs.ini' doesn't exist, trying to regenerate it
2022-10-03 17:48:21.475 [WARN ] Plugins path 'C:\Users\Sledziu\AppData\Local\Enderal\plugins.txt' doesn't exist, trying to regenerate it
2022-10-03 17:48:21.479 [INFO ] Redirections attached successfully, plugin loaded
2022-10-03 17:48:30.620 [INFO ] Redirections detached successfully, plugin unloaded
2022-10-03 17:48:30.620 [INFO ] Skyrim Redirector stopped.
It wants me to install base Skyrim after starting via launcher.
Hello Sledzward and welcome to the forum :-)
First of all, basic questions:
Which version of Skyrim do you own? There are different versions (Steam, GOG...).
And which version of Enderal do you want to install?
The classic or the special edition? Both Enderal versions require the possession of the corresponding versions on Steam. Skyrim does not have to be installed on your PC.
I got steam version, want to install classic, i got Skyrim LE in my library
So you want to install this Steam Enderal version?
https://store.steampowered.com/app/9334 ... n_Stories/?
Yes, i got it installed already
Did you try a clean install (see above in this thread)?
As I said, Skyrim does not have to be installed!
Also delete all corresponding Skyrim rest folders (if present) manually.
edit: did you start the following files with admin rights?
Enderal Launcher.exe, tesV.exe and skse_loader.exe
I tried today and the issue still occurs.
I never installed Skyrim on this laptop so i didnt get any folders from it.
I get them admin rights and also whitelisted in antivirus, sometimes SKSE will launch classic Skyrim menu, sometimes Enderal Launcher wants me to install classic Skyrim.
I have done every step in this thread, but i noticed that steam thinks my classic Skyrim is installed even if i only got the tesv.exe in Enderal folder.
Hello Sledzward
Do you have Enderal installed including Steam on the internal drive C:\ or on an external drive?
(External drives are usually a problem here, sometimes even if Steam and Enderal are on different drives).
Can you send us the launcher.log file as an attachment to the post?
(You can find it at: ...\Steam\SteamApps\common\Enderal\EnderalLauncher\system\log)
A verification of the installation with Steam you have already done?
Can you test install Skyrim in parallel with Enderal and then run the two games alternately?
I have steam on "c:\Steam" after clean reinstall.
Yes, i made an validation.
Im gonna try install them both.
SkyrimRedirector.log
(1.07 KiB) Downloaded 269 times
We asked for the launcher.log :wink:
