I just installed the game. I am running everything in admin mode. I have already verified the game flies with steam 3 times and it gives an all clear. Turned off all my antivirus and such. When I go to launch Enderal from the launcher it instead redirects me to an install Skyrim prompt from steam. Anyone know what is happening?
hi, welcome to the forum
try to delete the two *.ini from (...\Documents\My Games\Enderal);
(the game will create new ones on launch)
and restart the game (via Steam -> launcher, don't use shortcuts please)
you could also check the paths in Data/SKSE/Plugins/SkyrimRedirector.ini,
they should point to the aforementioned ini files.
if it doesn't work, please attach the launcher.log from ...\Enderal\Enderallauncher\system\log.
thank you
thank you
double post for visibility -
could you please upload the mentioned SkyrimRedirector.ini?
thank you
thank you
So I tried all that and still no go. I can't find a SkyrimRedirector.ini only a SkyrimRedirector.dll. I have attached the launcher log.
Launcher.log
(47.3 KiB) Downloaded 436 times
Could you please also upload the SkyrimRedirector.log
You can find it here:
Steam\steamapps\common\Enderal\Data\SKSE\Plugins\SkyrimRedirector.log
I do not have SkyrimRedirector.log. Only a SkyrimRedirector.dll that I cannot upload.
That should not be
- Could you check, if there's a write protection on the Enderal Folder?
- “Controlled File Access” might also block. Disable it or whithelist the game folder.
That did it. The folder was set as read-only. Flicked it off and it worked. Thank you!
21.04.2019 15:28Kermit 61 wrote: That should not be![]()
did Enderal suddenly stop launching correctly?
your answer over there makes it sound as if you're already playing
if the launcher suddenly launches Skyrim instead of Enderal, please upload the SkyrimRedirector.log from Data/SKSE/Plugins/
