Its started after the update when after a long time not playing, tried opening a new game, appeared at a tavern with no equipment equipped, when tried accessing inventory, it crashed, then i launched again, same thing happening, went to nexus mod manager(NMM) disabled every single mod, even the ones that were meant to Enderal. Then game started immediately crashing after pressing button launch, no mods active, no extra data files, unclear what to do next. Will put my save file as attachment
Save 144 - Richard Ark Foreign Quarter 05.45.15.ess
(2.63 MiB) Downloaded 227 times
welcome to the forum
- we'll need the skse file too - pack them in a zip / rar archive, the forum doesn't like them otherwise
the first problem sort of sounds like an ini problem.
could you take a look at the skyrim.ini in Documents\My Games\Skyrim and
check if the Enderal-Masters are listed under [Archives]?
the save doesn't load for me;
can't say if that's because of the missing mods, the missing skse, or the other problem
We had a similar problem yesterday in the German forum (https://forum.sureai.net/viewtopic.php? ... 5&start=10).
Enhanced Blood is no longer compatible with Enderal! It changes scripts.
I was able to load your savegame without any problems when I activated Enhanced Blood (no other Mod activated).
Try the following:
Activate Enhanced Blood, load the savegame, change the location (go to a tavern for example), save the game (no auto or quicksave), exit Enderal, deactivate Enhanced Blood, load the last savegame.
For me this worked.
After that you can gradually test your other mods.
Try the following:
For me this worked.
I tried activating some mods, and disabling them, still not able to open the game, can't even trie to load any save file, instantly crash. Tried activating Enhanced Blood Textures, same thing happened, not sure what to do next...
The windows says : Skyrim stopped working(its Portuguese, if anyone wats to google tradutor it), in a quick way.
Did you install SKSE separately? What a mistake would be. SKSE (not the newest version) is integrated in Enderal.
urst asked for a complete savegame. The .skse was missing. You need to pack the file as zip or rar to upload it here.
Make a clean install from Enderal. Look here: https://forum.sureai.net/viewtopic.php?f=208&t=10077
Uninstall Enderal, uninstall Skyrim. Clear the game's main folder.
C: \ program files (x86) \ steam \ steamapps \ common \ skyrim
Reinstall Skyrim. Never try to repair Skyrim over steam !!!
Install Enderal (use the actuell launcher version from enderal.com), make the update.
Try to reload a savegame. You may need to activate Enhanced Blood once (as described above).
First install no other mod!
Do not install SKSE.
before reinstalling everything, try deleting the ini files in the mentioned folder
(the game will generate new ones on launch)
maybe that already helps
Update : I reinstalled everything, done most of the things everyone told to do. Tried starting game without Skse, doesn't allow me, downloaded the installer of the new version, and run it, everything went fine. Pressed Lauch and it went fine, pressed load/continue and it went to loading zone, than it immediately crashes, without warning, or " Skyrim not working", just immediately crashes and goes back to the launcher. Tried launching it with the Enhanced blood mod, #crashes immediately after launch I pressed, deactivated it, same thing as before it was activated, unsure what to do next. Obs: after pressing continue the save or load the save, it says I have contents that are not availed(probably simple mods).
Thank you for you time, RicJan
Another update, tried starting a new game,what happened, not sure?
also not sure
THe textures appear... well this
Part2
I believe its wronng
This appears for menus,help
- do not install skse separately; newer versions than the included one are not compatible (from what I understand)
- do not install Enhanced Blood. it's not responsible for that, but otherwise not compatible with Enderal anymore,
and will most likely cause problems, including plotstoppers
- we had that texture issue just yesterday;
it's marked as solved, though I'm not entirely sure what solved it :/
it was most likely a corrupted install file
- where did you download that from?
follow the instructions here, and use the torrent download - option.
(if you're familiar with that. it would be the safest.)
don't give up, we'll get thtis to work
Update: I reinstalled well, EVERYTHING, it appeared that the file that i downloaded last time(with torrent) went wrong, that's why it was like that, so everything is working, but to load the file i have to have Enhanced blood activated , if i try to load without it it crashes, any ideia, you guys are saying the blood mod causes scripst to working in a wrong way so i really want to play without it before my game glitches , so please ,if you can offer any help thanks.
And thank you for all the people that helped/tried to help me, you guys are awesome
Did you try what I suggested because of enhanced blood?
For me this worked with your savegame. It is important to change the place once before saving.
Yeah i kinda did that be accident and it worked and made my game way more stable soo, thank you
