17 posts • Page 1 of 2
Bugged saves
Post by CommanderGepard »
I didn't play Enderal few months. I updated the game but when it loads everything is blue and i can't see anything. I think it's because i have saves from old version of the game and now i updated it. Is there a way to fix this?
Re: Bugged saves
Post by urst »
welcome to the forum :)
that kind of sounds like an *.ini issue
- what exactly do you mean with "just blue"? skybox?
- did you play Skyrim in the meantime?
- can you load an earlier save?
- please attach:
--- a savefile - found in
Documents\My Games\Skyrim\Saves - we need two files, the *.ess and the *.skse;
pack them as a rar, or zipfile or something
---and the skyrim.ini - found in
C:\Users\fading\Documents\My Games\Skyrim
Re: Bugged saves
Post by Hoxyd »
You could also try re-download all updates to make sure nothing is missing.
Close the Launcher, go to your game installation folder, open your launcher config file with notepad ..\Skyrim\EnderalLauncher\system\config\conf.sur Change the one entry to:
sCurrentVersion=1.1.0.0
Save and do the updates via Launcher. Ingame open your console "^" and type the following to make sure you are not at a missing location:
coc Seenlandschaft
If it is sill bugged, you should upload your save files.
Yes, I meant skybox. I can load earlier saves.
Skyrim.ini
(1.92 KiB) Downloaded 53 times
enderal saves.zip
(1.3 MiB) Downloaded 45 times
Re: Bugged saves
Post by urst »
your save works just fine on my game -
have you tried reloading the update?
you also could force the game to recreate the inis,
deleting both from that folder should do
not so sure if that helps though;
it looks (to my inexperienced eye) good, if the masters are correct
those in the ini are
[+] as follows
EEN - MeshesLOD.bsa,
EEN - Meshes.bsa,
EEN - Music.bsa,
EEN - Scripts.bsa,
EEN - SoundFX.bsa,
EEN - SoundVoice.bsa,
EEN - SoundExtra.bsa,
EEN - TexturesLOD.bsa,
EEN - Textures1.bsa,
EEN - Textures2.bsa,
EEN - Textures3.bsa
are these the same as in Steam\SteamApps\common\Skyrim\Data or is something missing?
if everything's listed, recreating is probably pointless
I reloaded the update. I launched the game and this showed up:
Application load error P:0000065432
And everything is on the list, nothing is missing.
Re: Bugged saves
Post by urst »
hm, apparently this error is should be (TM) fixable by deleting "clientregistry.blob" in you Steam directory (with Steam closed obviously).
(for example according to this (german) thread);
(which also states that you should generally open Steam before the Enderal launcher, and play offline,
don't know, if that does.. something :?: )
hope that helps :)
EDIT:
I'm not sure, what deleting that file does, but it's completly possible that you have to login into Steam again,
so maybe don't do that without having your password ready ;)
Error doesn't appear anymore but I still see only skybox. :(
Even when i start a new game i see only sky box.
I tried reinstall the game but it didn't help.
I dont know what to do anymore. :cry:
Re: Bugged saves
Post by urst »
:shock:
did you start Skyrim before installing Enderal?
does that work as it should?
otherwise...
you said, you could load earlier saves.
what happens if you load one of those and enter the bugged area (Ark?)?
maybe it's really just that one save that's bugged beyond repair
and you could keep playing using an old save :?:
I loaded earlier saves but they are also bugged. Every location, not only Ark. But it looks like Skyrim also doesnt't work. When i launch it the screen is green and the game crushes.
