13 posts • Page 1 of 1
setstage doesn't work to progress as suggested.
updated launcher to latest patch for English Enderal as suggested.
When using the setstage MQ11b 80 all it does is make Jesper walk into objects and glitch out.
the supposedly solutions of using MQ11b does not work and the instructions given to use them to progress the quest are poor and incomplete.
I would like a clear definition of this bug and why its mattered as a resolved fix when it clearly is not.
Reason: Moved to support.
Edit: Set my comments in spoiler brackets. Read the last comment. It's fixed. It will be patched soon. 02.11.2016
Try to
setstage mq11b 80
then
startscene 110655
If that does not work write back. Thanks.
followed setstage and startscene and nothing Jesper just glitches into terrain.
After leaving house Jesper still glitches into object and doesn't correct himself and doesn't progress
http://imgur.com/a/uYYHm
So after trying the commands again he walks all the way back to ark and goes to the bar and sits and I cant interact with him at all.
screen capture showing save data and him sitting down after taking me all the way back to ark
http://imgur.com/a/85un3
Ok, back to the powder desert together with Jespar.
before: setting the stage on 80
getstage mq11b
Other try:
resetai
disable
enable
(while he is selected in the console)
If that not helps upload your savegame.
A savegame consists of two files: one .skse and one .ess (please zip them)
Thanks.
Here is what worked for me.
1. Go to Jespar's estate with him, he doesn't talk, just follows you around.
2. At the estate, enter Setstage MQ11b 80 then immediately Setstage MQ11b 85.
3. Then talk to him and go to the Old Shadowsteel Mine NE of the estate.
4. Proceed thru the mine looking for a side path with a heavy steel door (Skyrim dungeon type), go thru & kill 2 skeletons. Just past that is another heavy steel door.
5. Stand there and enter Setstage MQ11b 90, then setstage MQ11b 95, then Setstage MQ11b 100.
6. Open the door and follow the path until you are hidden in some bushes and you see Jespar and Adila. Do NOT get closer yet. Everything should then proceed normally.
@Tilliboy Moderator,
Your method worked up to pass killing Adila, no glitched wit the mysterious lady reviving Jesper.
Now Jesper is laying on the floor and I see no further progression. so I don't know if it's still glitched or I'm suppose to wait for Jesper to stop freaking out?
Upload two savegames (one before Jespar's house and one with Adila)
having the same issue, he doesn't talk at all. no set stage or startscene helped, same with disable/enable and resetai. have attempted all instructions...
really wanna progress though the story, is there a way to just add the stone to my inventory and skip the quest altogether so i can just go on? I'll watch it on youtube or something if i can't find a fix for this....
save.zip
heres my save before any console commands were used
(1.68 MiB) Downloaded 365 times
@mynameisblaag
setstage mq11b 70
setstage mq11b 80
setstage mq11b 85
setstage mq11b 90
setstage mq11b 95
You will miss a lot of dialogue. Check out a Youtube Video.
I'll try my best to find the bug but.. we have already searched for so long.
Do you guys have a save before you talked to Jespar in Duneville. Would be awesome!
I do have one save but was told on bug tracker I use to many console commands and they needed a clean save,
Sorry for the delayed response every day work keep me busy,
http://sureai.net:9898/browse/ERB-1050
Save 422 - Reyui Sun Temple Emporium 19.21.07.ess
right before powder desert
(3.68 MiB) Downloaded 246 times
Fixed, finally! Load https://www.dropbox.com/s/gsdgtdf2p82w6 ... 9.esp?dl=0 to get through this scene correctly.
when I get to Jespar's old manor nothing happens, he doesn't detect he is there so I can't move on please tell me the console commands to get past this it's so annoying and I can't progress!
