11 posts • Page 1 of 1
Has anyone succeeded in getting in Enderal launcher to work?
I've installed and played successfully on Windows, copied over entire Skyrim folder to PlayOnLinux cdrive, let Steam discover it.
Enderal Launcher starts, it seems to be missing fonts though, anyone have an idea which ones it needs?
https://i.imgur.com/xlvN35a.png
I'd link as image but that isn't allowed as first post.
Edit1:
Found this post: http://forum.sureai.net/viewtopic.php?f ... =10#p74616
WINEDLLOVERRIDES = Scrrun = n
in Arguments for Enderal Launcher resolved fonts!
Edit2:
Tried starting enderal but it appears to start a half way modded Enderal, launcher window doesn't update after restarting anymore.
Edit3:
Debug mode does start launcher normally
Edit4:
After using Update in launcher the launcher window no longer updates in both normal and debug mode.
Try to completely install via wine with
    $ winetricks -q dotnet452
and do not forget to build a new 32bit prefix and set the winversion to 2003 or higher
The installation of dotnet452 forcibly sets the winversion to 2003 - but this does not affect skyrim/enderal at all.
I always launch enderal by directly calling skse_loader.exe - I only use the launcher to install updates.
Can start but appears to crash on new game or load game:
Skyrim has crashed. A minidump containing debugging information is being written
to C:\users\az\My Documents\My Games\Skyrim\SKSE\Crashdumps\2016-08-19_15.35.31
.dmp.
Minidump written
I've attached two in a zip file to this post.
Edit:
Tried installing from scratch with wine but Enderal Launcher crashes.
Crashdumps.zip
2 zipped crashdumps
(38.25 KiB) Downloaded 209 times
guess it would take someone more skilled than me to do anything with that crashdump.
Have you been able to run Skyrim with wine?
And if the launcher is not running, how did you install Enderal?
jd42 wrote:
Tried with Skyrim folder copied over from Windows partition first then tried installing from scratch.
Skyrim launcher starts but I cannot click anything, launcher window doesn't appear to refresh/update.
Dumped PlayOnLinux as their dotnetfx scripts appear to be broken.
Ran through below steps and got as far as launching Enderal:
sudo add-apt-repository ppa:wine/wine-builds
sudo apt-get update
sudo apt-get install --install-recommends wine-staging
sudo apt-get install winehq-staging
WINEARCH=win32 WINEPREFIX=~/.wine32 winecfg
Libraries: d3dx9_42 to native
Copy over winetrick files or repeat whole process when they are in cache, redoing in existing wineprefix breaks
WINEARCH=win32 WINEPREFIX=~/.wine32 winetricks dotnet45
WINEARCH=win32 WINEPREFIX=~/.wine32 winetricks corefonts
WINEARCH=win32 WINEPREFIX=~/.wine32 wine SteamSetup.exe
Start steam, install skyrim(or copy over files), start skyrim, dotnet takes a looong time.
Download Enderal launcher exe and 8GB gz file
WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n wine "Enderal Launcher.exe"
Output after attempting to run Enderal Launcher:
$ WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n wine "Enderal Launcher.exe"
fixme:winediag:start_process Wine Staging 1.9.16 is a testing version containing experimental patches.
fixme:winediag:start_process Please mention your exact version when filing bug reports on winehq.org.
fixme:process:SetProcessDEPPolicy (1): stub
fixme:wer:WerSetFlags (2) stub!
fixme:heap:RtlSetHeapInformation (nil) 1 (nil) 0 stub
fixme:process:SetProcessShutdownParameters (00000380, 00000000): partial stub.
fixme:ver:GetCurrentPackageId (0x83d934 (nil)): stub
err:ntdll:NtQueryInformationToken Unhandled Token Information class 29!
fixme:ver:GetCurrentPackageId (0x33f4dc (nil)): stub
fixme:ver:GetCurrentPackageId (0x33f6c4 (nil)): stub
fixme:process:GetNumaHighestNodeNumber (0x33fb40): semi-stub
fixme:thread:SetThreadStackGuarantee (0x33fb24): stub
err:ole:CoGetContextToken apartment not initialised
fixme:time:QueryThreadCycleTime (0xfffffffe,0x3c92560): stub!
fixme:shell:URL_ParseUrl failed to parse L"System.Windows.Forms"
fixme:shell:URL_ParseUrl failed to parse L"System"
fixme:shell:URL_ParseUrl failed to parse L"System.Drawing"
fixme:nls:GetUserPreferredUILanguages stub: 8 0x33e2e8 (nil) 0x33e2e4
fixme:nls:GetThreadPreferredUILanguages 00000008, 0x33e2e8, (nil) 0x33e2e4
fixme:nls:get_dummy_preferred_ui_language (0x8 0x33e2e8 (nil) 0x33e2e4) returning a dummy value (current locale)
fixme:nls:GetUserPreferredUILanguages stub: 8 0x33e2e8 0x17f7c0 0x33e2e4
fixme:nls:GetThreadPreferredUILanguages 00000008, 0x33e2e8, 0x17f7c0 0x33e2e4
fixme:nls:get_dummy_preferred_ui_language (0x8 0x33e2e8 0x17f7c0 0x33e2e4) returning a dummy value (current locale)
fixme:ntdll:EtwEventRegister {8e9f5090-2d75-4d03-8a81-e5afbf85daf1}, 0x9a0312, (nil), 0x1559bc8
fixme:shell:URL_ParseUrl failed to parse L"Enderal Launcher.resources"
fixme:nls:LCMapStringEx unsupported lparam 18bc60
fixme:shell:URL_ParseUrl failed to parse L"Accessibility"
fixme:gdiplus:GdipGetFamilyName No support for handling of multiple languages!
fixme:shell:URL_ParseUrl failed to parse L"System.Configuration"
fixme:shell:URL_ParseUrl failed to parse L"System.Xml"
fixme:ole:CoGetApartmentType (0x33e348, 0x33e2b8): semi-stub
fixme:wshom:WshShortcut_QueryInterface Unknown iface {c3fcc19e-a970-11d2-8b5a-00a0c9b7c9c4}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {b196b283-bab4-101a-b69c-00aa00341d07}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {af86e2e0-b12d-4c6a-9c5a-d7aa65101e90}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {ecc8691b-c1db-4dc0-855e-65f6c551af49}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {94ea2b94-e9cc-49e0-c0ff-ee64ca8f5b90}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {00000003-0000-0000-c000-000000000046}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {00000144-0000-0000-c000-000000000046}
fixme:wshom:WshShortcut_QueryInterface Unknown iface {a6ef9860-c720-11d0-9337-00a0c90dcaa9}
fixme:service:QueryServiceConfig2W Level 6 not implemented
It crashes, however! Enderal files are placed in .wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/!
Can start Enderal Launcher.exe from there with:
WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n wine "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/Enderal Launcher.exe"
Installation and update through launcher goes well.
Changed settings to disable OneTweak and vsync, lowered windows resolution
Can start Enderal through launcher!
When attempting to start a new game menu keeps playing, menu disappears, just background, no errors appear, skse_loader shows nothing odd to me either: https://i.imgur.com/fDxjajW.png
On load game (it copied steam cloud savegames) I get the following message: https://i.imgur.com/7eQtCXb.jpg
Same happens if I start Enderal through:
WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n wine "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/skse_loader.exe"
So close!
I assume it has to do with the initial Enderal Launcher startup?
Enderal replaces Skyrim.esm and Update.esm with its own version.
This is vanilla Skyrim (english):
-rw-rw-r-- 7 dummy dummy 249371467 Feb 1 2012 Data.vanilla/Skyrim.esm
-rw-rw-r-- 7 dummy dummy 1518686 Mär 27 2013 Data.vanilla/Update.esm
This is current Enderal (german):
-rw-rw-r-- 1 dummy dummy 144922471 Aug 12 22:37 Data.enderal/Skyrim.esm
-rw-rw-r-- 1 dummy dummy 810010 Aug 10 20:38 Data.enderal/Update.esm
Your sizes may differ, but the vanilla files are much bigger... so please check if you have the Enderal version of those...
If you still have the original skyrim files, then the Enderal installation did not work. In that case, please also check the launcher log (EnderalLauncher/system/log/Launcher.log). While most files are included in the big download file, Skyrim.esm and Update.esm are donwloaded separately by the launcher.
Filesizes appear to be ok: https://i.imgur.com/VIDMRIu.png
Left is on Kubuntu, right is on Win10.
I've attached my Enderal Launcher log, didn't see anything odd myself.
Thanks for helping out so far, appreciate it.
Launcher.log
(104.84 KiB) Downloaded 297 times
Resolved!
Per https://ubuntuforums.org/showthread.php ... st12761784
You have to change to the path the Launcher/skse is in!
Command to use:
cd "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/" && WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n wine "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/Enderal Launcher.exe"
On savegame load Skyrim warned about running out of vram.
Set VRAM by below steps:
Check amount with
grep -i --color memory /var/log/Xorg.0.log
or
grep -i --color vram /var/log/Xorg.0.log
or
lspci -v | grep -i VGA -A 10
or
echo $(dmesg | grep -o -P -i "(?<=vram:).*(?=M 0x)")$" Mb"
WINEARCH=win32 WINEPREFIX=~/.wine32 winetricks settings
Set videomemory to 2048
WINEARCH=win32 WINEPREFIX=~/.wine32 wine regedit
Browse to
HKEY_CURRENT_USER\Software\Wine\Direct3D\ and change video memory size to your videocards amount of memory in MB
Add some more performance by running:
and tick Enable CSMT for better graphic performance, like below:
https://raw.githubusercontent.com/wiki/ ... g-csmt.png
Start with WINEDBG=fps to show fps in terminal when game runs.
cd "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/" && WINEARCH=win32 WINEPREFIX=~/.wine32 WINEDLLOVERRIDES=Scrrun=n WINEDEBUG=fps wine "/home/az/.wine32/drive_c/Program Files/Steam/steamapps/common/Skyrim/Enderal Launcher.exe"
