9 posts • Page 1 of 1
Clicking "Launch Enderal" in the launcher gives an error sound and doesn't load the game. I've tried using the skse_loader as well as the SkyrimLauncher in the game directory. It gives me the same results.
It's probably the best to reinstall Enderal. Uninstall it first by clicking on the "change installation" button. Then just follow the steps. Skyrim gets restored. Now you have to install Enderal again. Follow these instructions and/or this step by step screenshots.
I have the same issue. I have uninstalled and reinstalled several times but still the same issue. I click 'Launch Enderal' and a sound from the launcher/game is heard, then followed by a windows error sound. You can see Skyrim running as a process using only 32MB of memory and have to end it in Task Manager.
Ok, could you attach your LauncherLog ?
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
Mine is as attached.
Launcher.log
(74.8 KiB) Downloaded 86 times
Did you used the archives function to back up Enderal? Uninstall it completly. Try a fresh reinstall with the installation package.
Maybe you should try out another hoster. (moddb, nesxusmods, torrent @ http://enderal.com)
I have used both methods. Complete uninstall as well as archive. Same result.
Am i right, when I say that you are executing Enderal from this path: E:\games\\SteamLibrary\SteamApps\common\Skyrim\EnderalLauncher\backup\enderal\
It could be that the launcher can't find you files (normally it should find them).
Maybe try to install Skyrim in program files: C:\program files(x86)\Steam\steamapps\common\Skyrim
Correct, that is where my Skyrim directory is installed as it is on a separate "game" hard drive. I will try and move it across.
