So I had to wipe my old Skyrim saves and files because of the old mods to get a "clean save" of Skyrim to not interfere with the Enderal mod itself. Downloaded the Torrent, downloaded the Enderal Launcher, everything was installed just fine or atleast thats what the launcher told me. So I go and try to Launch skyrim, click "Play" on the small startup screen that pops up first, then I'm greeted with a nice custom loading screen meaning that the launcher has actually installed atleast SOME parts of Enderal in my Skyrim. Then 3 seconds with the loading screen and I get a popup saying "Master file not found: Skyrim esm, Required by: Update esm". No idea what should I try to do here ?
Launcher.log
And there is the LauncherLog
(9.42 KiB) Downloaded 323 times
eMCEE86 wrote:So I had to wipe my old Skyrim saves and files because of the old mods to get a "clean save" of Skyrim to not interfere with the Enderal mod itself. Downloaded the Torrent, downloaded the Enderal Launcher, everything was installed just fine or atleast thats what the launcher told me. So I go and try to Launch skyrim, click "Play" on the small startup screen that pops up first, then I'm greeted with a nice custom loading screen meaning that the launcher has actually installed atleast SOME parts of Enderal in my Skyrim. Then 3 seconds with the loading screen and I get a popup saying "Master file not found: Skyrim esm, Required by: Update esm". No idea what should I try to do here ?
You're supposed to run the Enderal launcher, apply the updates and then launch Enderal via the Enderal launcher. Skyrim is not involved in the whole process.
Seems like I forgot to actually update Enderal AND I did try to launch Skyrim from Steam
I will update the Enderal now and try to launch it from the Enderal launcher.
Than you for your reply !
eMCEE86 wrote:Seems like I forgot to actually update Enderal AND I did try to launch Skyrim from SteamI will update the Enderal now and try to launch it from the Enderal launcher.
