23 posts • Page 1 of 2
After the loading screen my game just crashes, no error messages or anything
bump
i get this aswell...
enabled crash logging and got this, dunno if its helpful
Crash info:
2016_08_15_10-46-42 - 25C0D6E: V(1); EAX(0); EBX(5); ECX(EF7B148); EDX(0); ESI(47F9BE8); EDI(0); EBP(1); ESP(4C1FFADC); STACK(CD39FA AB9999 CAFE9C CB007F CC9BCC CABFD4 CA5434 C7C7D5 C7F240 897078 87B65B);
further edit:
ive scoured these forums and tried everything, my skyrim is installed on my second hard drive mainly because my main is only 80gb. i just cant get it to work
I am also getting this problem.
I get the crash when trying to start a new game. I get an error message with this text: Skyrim has crashe dbecause an object reference with form ID:0x125531, base form ID: 0x67137 and type: 0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons.
I attached my log file too
Launcher.log
(41.87 KiB) Downloaded 296 times
Still no fix?
Working for me now.
Make sure that if you downloaded skse before you installed Enderal you delete skse and then reinstall through the launcher because skse will download through that.
mesh corrupted
Post by emris »
hello, if a start I get an error message with this text: Skyrim has crashe because an object reference with form ID:0x14C272, base form ID: 0x9A787 and type: 0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons.
I saw someone with a similar problem that was resolved by removing and reinstalling the SKSE via the launcher. Except that I did not have SKSE, it was downloaded directly via the launcher. Any idea please ?
I hope this will help you.
I managed to get rid of the very same ctd by deleting skse in the Skyrim directory and downloading it from skse.silverlock as 7z archive.
I have this problem too. No idea what to do about it. Could a developer of the mod come around and give some information?
i just reinstalled skyrim and did a fresh install :/ renamed my skyrim folder with my mods, and just redownloaded it through steam
Hey guys, im not sure if I should ask for help here but im receiving and error message everytime I try to open the english version.
"skyrim has crashed because an object reference with form id: 0x14c272, base form ID:0x9a787 and type:0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons."
Can anyone help me out?
Re: mesh corrupted
Post by stuemper »
Try another file hoster for the installation package and follow these instructions and these step by step installation screenshots.
I hear you. I followed the directions, let everything download and update. The loading screen comes on just fine. Whenever I try to create a new game, it will start up the loading screen and then give me a message that says "Skyrim has crashed because of an object reference with form ID: 0x125531, base form ID: 0x67137 and type: 0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons." If it means anything, on the launcher, if I click on data files, there is nothing loaded there. I figure that this is probably a mod or SKSE issue.
Install the newest update and then attach you LauncherLog:
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
Could also be a mistake during the installation.
Uninstall Enderal. Verify Skyrim Cache in Steam. Install Enderal with this instruction.
Check out these step by step installation screenshots.
Crash on New Game
Post by kamaru004 »
Hi. I installed Enderal and Skyrim for at least five times now and I can say that it is the cleanest install possible. I followed the instruction but still no avail. I still get this upon new game.
All I have is the error message:
"Skyrim has crashed because an object reference with form ID: 0x125531, base form ID: 0x67137 and type: 0x22 failed to produce loaded node most likely due to corrupted mesh or other reasons"
Ive performed a clean install like 3 times now, testing each with a different Enderal.gz file.
i'm having the same problem but with form ID: 0x14C272 base form ID: 0x9A787 and type 0x22
Re: mesh corrupted
Post by Alcahoney »
Having the EXACT SAME problem. Getting the same error message.
The Skyrim install I use is the legendary edition that automatically installs all DLCs. but that shouldn't be the problem, should it?
Re: mesh corrupted
Post by stuemper »
The DLCs should not be a problem. I use the legendary edition, too. I have no problems at all. It could be that Steam wants to reinstall them after the Enderal installation is done. Disable the Steamcloud and auto-update of Skyrim. Then install Enderal.
It could be mods/ENBs interfering. Make sure you have disabled them and unsubscribed them in the Steam Workshop or if you use a mod manager make a new profile.
It could be the .ini's. Remove them. Verify Skyrim's game cache and then do a clean install of Enderal with this guide.
Also check out this SKSE version+.ini's.
