10 posts • Page 1 of 1
I just downloaded Enderal and when I go to load into a new save it is stuck at a loading screen . I tried re downloading skyrim and the mod. If anyone could be of assistance that would be great.
Thanks
I am having the same issue. Just sits at loading screen forever doing nothing. Help.
The game actually started for me for about 8 seconds, then it locked me up, had to restart computer.
Tried to get back in, "Enderal needs an update", Nope, checked 5 times, uninstalled Enderal, resinstalled it, game loads, NOW it sits on a black screen when I click "New Game"
Launcher Log is attached, please help.
Thanks.
Launcher.log
(64.5 KiB) Downloaded 455 times
Thanks
What do you mean by "stuck at a loading screen". Is Enderal/Skyrim Enderal just going "inactiv" in the task manager? - If yes let it load, do not click around. Or does the whole game shuts down and crashes to desktop immediately?
A LauncherLog of both of you would be good.
C:\program files(x86)\Steam\Steamapps\common\Skyrim\EnderalLauncher\system\log\launcher.log
Thanks.
Seems like the launcher can't find your steam directory:
Steam status: False
Do you use some "special" pc configuration? Steam seems to be on an external hard drive?
Here is my log file. This is the problem: When I select new game and then say yes I do want to start new, It just sits there with the skyrim logo on the left side with a black screen and the fog moving around. Nothing else. Stays like that indefinitely. Anyone got a fix for this yet?
Launcher.log
(22.14 KiB) Downloaded 415 times
just reinstalled Skyrim for this mod and same here 20min loading screen and nothing happens
Tilliboy wrote:
Thanks
Thanks.
Steam status: False
I run my operating system on an SSD, everything else runs from a typical HDD. Saved games are stored on the SSD though, could that be the problem? Anything fundamental I can look into the help figure out my problem?
I'm also perpetually stuck in the 'New Game' loading screen. I've done a fresh install of the game as well with no fix. Any help?
Launcher.log
Launcher Log
(47.8 KiB) Downloaded 413 times
Problem: Stuck at Main screen where you choose "New" game. I click on "New" game-Nothing but a nice view of mountains/waterfall screen-smoke and some choir singing...
What I've done:
Restarted computer
Ran the Launcher as an administrator
Ran the Enderal launder-Patched the mod (It's patched)
Reinstalled Skyrim from Steam
Reinstalled Enderal both from Nexus then from Torrent !!~
I am still stuck
What I am using:
Windows 10 x64
Nvidia 970
:cry:
Your logs seems fine. Mhmm. Try out the newest Launcher.
The newest launcher should detect corrupted installation packages.
Otherwise I just can recommend to reinstall (do not use the archive function for Enderal - use the installation package) with this instruction and this step by step screenshot gallery.
Maybe try a installation package from a different hoster (recommended: torrent)
