26 posts • Page 1 of 3
Hey,
I've downloaded the Launcher and the full installation package from the site and placed them in the directory where Skyrim's files are, but whenever I engage the Launcher to run nothing happens. I have tried running as an Administrator, removing and re-installing the Launcher, restarting the computer, and Unblocking in properties--however, nothing works.
It's strange, since other people seem to at least be getting the Launcher's dialogue boxes highlighting that something is wrong, whereas there's no indication for me that the application has even started.
Any ideas?
Much love <3
Hey! Not sure, try this version: http://dl1.sureai.net/files/pro/enderal ... uncher.exe
Also post your log-file please. You can find it here: \Skyrim\EnderalLauncher\system\log\Launcher.log
I would, but no such subdirectory within the Skyrim folder exists--there's no EnderalLauncher folder.
Tried version you posted, but it's the same I used. Didn't stop me but had same results too.
Ok, .NET Framework 4.5 installed?
And tell me more about your system configuration :D
Yes, installed 4.5!
Would a screenshot of my system information do?
http://i.imgur.com/61Iga7Q.png
Thank you for helping!
Yeah.. You are playing on a notebook if I'm not mistaken. We had some trouble with notebooks (barely tested on notebooks).
Our launcher programmer (Hoxyd) will take care of your problem soon. :)
Oh, good! I'm very eager to play, it looks amazing. I've been rummaging through drives and installer packages trying to figure out any idiosyncrasies. Thank you!
Where should I check to see if any solution has progressed?
He will answer directly in your thread. ;)
Updated the Version on http://enderal.com, maybe this one will fix it.
I had this problem too... But now I solve this!
This happen if you Skyrim it's not in default folder (C:\Program Files (x86)\Steam\steamapps\common\Skyrim), put Skyrim in default folder and will work
