I have a problem installing this mod http://www.nexusmods.com/oblivion/mods/ ... w%3D&pUp=1 which is Robert Female Body Mod. Textures work fine for the human races but Aeterna not so and I don't know what to do. How could I make the textures properly appear? For example nails just have a bland texture and the skin texture appears all messed up.
Last screen here because max limit was 3:
I don't know about that mod, but have you tried this one?
http://www.nexusmods.com/oblivion/mods/45554/?
WARNING! Do NOT use V2.0 since it has a bug with the physic engine (floating swords when you kill enemies, and sometimes even floating corpses).
Rather use V1.3 which is fine
Tealor Arantheal wrote:I don't know about that mod, but have you tried this one?
Hmm, did you properly create an ArchiveInvalidation.txt after installing the new textures?
You need that text file as it tells Oblivion/Nehrim where to take its textures from
Way easier though would be this little tool here - you basically just run the .exe and follow the instructions ^^
EDIT: Unfortunately I don't have Nehrim on my laptop and it will take some more weeks till I can get back to my PC or I would try it myself to see if the tool works in Nehrim as intended; so we can just hope for the best, sorry for that
Sadly didn't work. Added images in OP for better understanding.
