I'm doing the Cleric quest where I go to the Ion Monastery to help with the "problem." I get the note referring to the skeleton hanging on the tree, find it, and see a note about disease, but I've been all over the area and no idea what to do next.
Hey badgesareus, in the German version of Arktwend, the quest ends at the skeleton with a journal entry along the lines of "I should give up that vain search", and you can go back to the prior in Stormwend who'll give you the next quest. Now I'm not sure if the English version - or The Arktwend Overhaul - has extended the quest line. Did you try to return to the prior and talk to him?
Thanks. Yes, the English version is the same. I found that note in my journal accidentally while looking for something else. I thought the journal just records known information, I didn't realize sometimes it provides entirely new information.
