2 posts • Page 1 of 1
Hello.i was trying to get OBGE to work for Nehrim but for some resson some textures were showing up purple so i totaly unistalld Nehrim and Oblivion but now if i try to install Nehrim im experinceing a very anoing problem with the launcher.Every time i try to go to the settings menu i get this message poping up''ini file is not correct.Use the Nehrim launcher in order to generate a new one'' .and if i click ok it just keeps repeating the message so the only way i can close the launcher is using ctrl+alt+del.I can run the game but i cant access the settings i have tryd unistalling and reinstaling Nehrim 4 times now with no sucess.please can somone help me reslove this issue.
Have you activated the game files in the launcher (Nehrim.esm and NehrimData.esp)?
If your ini-file is corrupted, you can delete it - the launcher/game will create a new and hopefully correct one. (the file path should be C:/Users/*yourName*/Documents/MyGames/Oblivion if you didn't change the file path in the launcher. Otherwise, it should be in your Nehrim directory).
