7 posts • Page 1 of 1
OBGE install?
Post by tillter123 »
today i got nehrim (im on steam) and i was wondering if anyone could give me instructions on how to install OBGE v3, thanks
Re: OBGE install?
Post by Andarmel »
1.Download and install OBSE
http://obse.silverlock.org/
2.Install DirectX-Update
http://www.microsoft.com/en-us/download ... aspx?id=35
3.Download OBGE-Packages
http://oblivion.nexusmods.com/download/81267 & http://oblivion.nexusmods.com/download/81205
4.Extract the OBGEv3 Core archive you downloaded into your Nehrim\Data directory.
5.Open the OBGEv3 Standalone Effects archive you downloaded. Extract the contents of the "00 Core" folder into your Nehrim\Data directory.
If you want to use the Godrays effect, also extract the contents of the "01 Godrays Sunglare Fix" folder into your Oblivion\Data directory.
Oblivion Graphics Extender Support.esp is not required.
I highly recommend to use this tool for shader selection: http://oblivion.nexusmods.com/mods/40052
Re: OBGE install?
i installed obge and obse the correct ways (ive done it before just not with nehrim) but i am not noticing any difference. il try what you recommend thanks
Re: OBGE install?
so i tried the mod you linked but when i try to save it comes up with an error saying some other process is using the file so it cant be edited
Re: OBGE install?
Post by Darkrael »
No need of OBGE anymore.
Look at this ._.
http://enbseries.enbdev.com/forum/viewt ... =11&t=2378
Re: OBGE install?
Post by Mike Adams »
I'm having the same issue.
Re: OBGE install?
Post by urst »
welcome to the forum :)
(never tried to use that myself, (and not sure what exactly is supposed to happen,) so I can only offer some general advise)
- what file is edited here? is there a write protection? (right-click on the file -> properties)
- could there be "some other process is using the file"? check the Task Manager (probably right-click on taskbar, use the detailed view)
- can you use admin rights?
