I just started playing the mod today and it was working perfectly until I reached Tirin Abbey and handed the letter over. 30 secs after the letter leaves my inventory the game crashes. I try an earily save and I getting the same problem. I also turned off the autosave. Does have the Boars and Goblin quest cause problems?
Can you upload your savegame here?
Here it is
Save 1 - Marcus - Fold Valley, Level 3, Playing Time 01.22.55.ess
(873.9 KiB) Downloaded 158 times
Hmm. I do get some crashes, but they're not reproducable, meaning that they're at different moments each time and sometimes I get through the Duras-Erik conversation (outside of the monastery) without any crashes. Maybe you can precise a bit what exactly you are doing before it crashes? Do you go inside the monastery, then talk to Duras, then talk to Aratornias, then leave?
I get hit up by the guy when i first walk in. Take the quest and then talk to the guy you gotta give the letter to.
I think the Goblins and Boars quest was causing the problem.
You can check it. If you are fast enough you can avoid Duras on your way to the upper level of the abbey. Does it crash then?
