3 posts • Page 1 of 1
So I installed Nehrim perfectly, including not putting it into the oblivion directory or the programFiles directory, and it just will not save!
I get into the game, everything works perfectly as it should, but no save files are generated when I save my game via the menu, or quicksave.
I have uninstalled, cleaned out old files, and reinstalled at least 4 times now, both in and outside of the ProgramFiles(x86) folder cause I heard that might have caused it, but to no luck, it just will not save.
When I go to save, it says "save successful" and all that, but no file :(
C'mon, someones gotta know how to fix this, any help would be appreciated..
Does your Nehrim have writing rights in your "My Documents" folder?
Yes, I have made sure that all the exe's in the nehrim folder have been given administrative rights, so that shouldn't be the problem...
Also, I have disabled the UAC, but it seems to make no difference.
FIXED: Well, it seems that even after the reinstalls, it was trying to save into the ProgramFiles(x86) folder. Had to go into the Oblivion ini file in the my documents/my games/oblivion/ and edit the save path manually to make it work.
