1 post • Page 1 of 1
These are the instructions for the room where the guy detects the traps for you and tells you how to move.
Here is the list of Narathzul's instructions:
-go to the left
-go forward
-go to the right
-go backwards
-go to the right
go forward
-go to the right
-go forward (under the bridge)
-go to the left
-go forward
go to the left
-go forward
- go to the right
-go forward ( into a passage)
Narathzul finds a switch and he will open the door in front of you.
This Cannot work. After the first right he saiy go backwards. so i backpedal back up to the wall. The guy says nothing. If you then went right, then forward then right again from this spot, you will not be under the bridge he is standing on, you will be back in the room you came from. either this is very badly translated or broken. Either way,
this cannot work. whats the deal?
Edit; I got it. it only works if you dont turn to face the direction your going in, you have to stay facing forward the whole time. i found it helps to take baby steps the whole way.
Next area, he tells you to put the stones we found into the fixtures. There is a locked door I cannot get through. there are no fixtures up where i am only down below where he is. i cannot get to him to put the stone in the fixture.
Grrrrr.. time again to check the walkthrough. good thing i switched regular cigarettes to the safer electronic cigarette because this game is making me vape (smoke) my head off. BTW, if you smoke, please try e-cigs, they will save your life and are way too much Fun to use.
