I left the Erothin jail and went through Erothin. The gaurds did not stop me as this wiki says http://nehrim.wikia.com/wiki/The_Escape. i followed the long bridge out of Erothin.
I have no green marker that I can find on the world or enhanced map. I headed towards Cahbaet from the main road only to find a locked gate. Backtracked and did not find any path leading up to a monestery. This sucks. now after reading thw wiki I have to go back to the jail opening and find my way to the northrealm without a green marker and just hope I go in the right direction. I have version 1111.
o.k. what gives? I looked at the map here http://images1.wikia.nocookie.net/__cb2 ... averns.jpg and the mountain monestery is no where near the northrealm. If this is the one I'm looking for the translators or game devs did a really poor job with this because the quest info indicates it should be found in the Northrealm someplace from a path left of Cahbaet. Especially since I have no green marker there is no way i could ever find this without better directions in the quest. I'd say this is a Major bug.
The guards should have stopped you, I failed the quest to experiment a few times
Most probably you do not have the green marker to the monastery, because somehow the script got broken?
I'm afraid that if the script got broken somehow you might not enter the Monastery, but I hope Arvisrend clears the issue or someone more experienced with how the quest works.
kassandra wrote:Hi,
the mountain monestery is no where near the northrealm. the quest info indicates it should be found in the Northrealm someplace from a path left of Cahbaet.
Quest markers only appear when you have the respective quest selected (by clicking on it in the Quests tab).
