Hi, I just downloaded Nehrim onto my new Windows 7 computer and when I open the launcher and click on "Data" to check (and uncheck) the necessary boxes it says that the launcher cannot find the data files. Never had this problem on my other computer (which was XP, but was so low-end that I could barely play Nehrim even on lowest settings). This computer has two hard drives; both Oblivion and Nehrim are installed on the secondary drive (ie, not on the boot drive) because the boot drive isn't large enough. Oblivion runs fine on the secondary drive. Has anyone else had this problem, and if so, how did you fix it?
Edit: Just tried dragging the Nehrim.exe into the Nehrim folder within the secondary drive (for some reason it had installed outside the Nehrim folder, even though the launcher, data files, and everything else had installed in there) and it seems to be working now. Just posting incase anyone else has had this problem... this seems to potentially be a way to fix it.
