1 post • Page 1 of 1
A small mod list for Nehrim
Mods Made by me
Exponential Levelling Nehrim (ELN) : http://tesnexus.com/...le.php?id=38191 : Ready to go : This version is for use with Progress & conflicts with NIE it overwrites the NIE level up messages but it not really relevant for users of the English version of Nehrim
Map Location & level Information Removal is packed with ELN : : ready to go but only use one of the ESP's : it removes the you are here & what level you should be to be Here messages from the hud
Mods I have converted for converted for Nehrim
Progress Nehrim : http://www.tesnexus....le.php?id=38189 : Ready to go final Version unless Tejon's does an update
The Nice Ones real sleep extended It is now up on the Nexus http://www.tesnexus....le.php?id=38266 & works as intended .
Mods not made for Nehrim but work out of the box
Kurtee Auto Save & time : http://www.tesnexus....le.php?id=22136 : Ready to go : Will work well with Streamline to give you at least some of the bells
Mods that only need minor change to work with Nehrim
Armourers advantage: http://www.tesnexus....le.php?id=26288 : Needs master reassigned to Nehrim : Loads OK but I haven't been playing enough to know if it's actually working
Better Timed Blocking : http://www.tesnexus....oads/search.php : Needs master reassigned to Nehrim
Sneaking Detection Recalibrated : http://tesnexus.com/...oads/search.php : Needs master reassigned to Nehrim : Highly recommended works almost out of the box is highly configurable
Streamline 2.1 : http://planeteldersc....Detail&id=2684 : Needs master reassigned to Nehrim : Download both files & replace the 2.0 esp with the 2.1 & reasign the Master to Nehrim it doesn't have all the bells & whistles of 3.1 but does a good job of controlling your frame rates, & with auto save & time will get you bye.
& i have a new Bilingual version of ELN in the wings just waiting for JOG's OK & it loads into the Bash Patch !
These are From Psymons List on the Bethesda Forums http://forums.bethsoft.com/index.php?/t ... d-mods-ii/
Leveling:
ELN , Progress & Skill independent attributes together make the best levelling mod combination so far for Nehrim Beebee
SPAM is purported to work.
Menu Management:
QZ Easy Menus
Toggleable Quantity Prompt (All of these are essential Beebee)
Display Stats
DarUI will conflict with NIE above plus you will lose some of the cool things about Nehrim Menus and interface. I would imagine that a version that only effects inventory and other parts of menues and character sheet would be very popular - more so if combined with NIE.
I don't think it's ever going to happen though
HUD:
Nehrim Colored Map Markers
HUD status bars (very nice little add on Beebee)
Hotkeys:
Fast Equipping Nehrim
Enhanced Hotkeys - amazing mod, recommended
STHotkeys
ROM Drop Lit Torches
Annoyance Removers:
Initial Glow mods both armor and weapon and only armor variants
Nehrim Camera Mod
Nehrim Refractionless Chameleon.
Denock Arrows
Zumbs Lockpicking Mod OBSE
Combat:
Deadly Reflex 5 replacement plugins
Hand-to-Hand for Nehrim
( the following 4 Mods with ELN & Progress, will significantly raise the bar in Nehrim )
ttribute-based and skill-based damage modifiers
Marksman's Challenge
Phitt's Phighting Phixes
Stealth:
Nehrim Sneak Fix - may be outdated with 1.0.8.0 patch. (it's still necessary Beebee)
StealhOverhaul_Nehrim (I prefer Sneaking Detection Recalibrated it is much more configurable but may conflict with Realistic sneak for NPCS )
Realistic Sneak for NPCs
Immersion-Realism:
Nehrim Improvment
Nehrim Bedrolls (unnecessary with Real sleep extended loaded )
SM Encumbrance and Fatigue
Kuertee Inventory is a backpack - not 100% sure but reported that it works.
Graphic Improvements:
OBGEv2 3.0 - the plugin does not work but loading shaders via the shader list does! Read the thread for updates you won't find on the Nexus download. ( In Nehrim I prefer Liquid Water it still has glitches & so far I haven't been able to get Godrays to work but the ini is a much better way to control shaders & the water look wonderful Beebee)
OBSE Plugins that so far work:
Oblivion Stutter Remover
Menu Que
Ref Stuff
ConScribe
INIzer (unnecessary with mTES4 http://www.tesnexus.com/downloads/search.php the most useful tool yet for Oblivion it allow you to have multiple independent installs of Oblivion & Nehrim )
OBGEv2 3.0mons
Regards For now Beebee
