So I decided to go check out Castle Darlan that I recieved a few quests ago. There are new Darlan guards, a statue of my character and so on. But the bodies of the soldiers that died in the liberation quest haven't been removed. It's not supposed to be this way, right? In that case, is it possible to "manually" remove the bodies somehow?
Thanks!
Thanks!
Did you liberate Darlan or Mortram?
Did you use any cheats during that quest or the next one?
Could you upload a (compressed) savegame? I would like to finally know how this bug comes.
I liberated Darlan, and I didn't use any cheats.
Anyway, I found out how to delete the bodies via console, so problem solved for me.
I've attached the savegame for you here. I hope I did it right =P
Save 1244 - a - Castle Darlan, Hall, Level 18, Playing Time 31.36.56.ess.7z
(833.01 KiB) Downloaded 193 times
