20 posts • Page 1 of 2
Nehrim won't start
Post by Duzjah »
Hello, I'm having a weird issue here...
I installed the game, it all went perfect, then in the NehrimLauncher I set those Data Files, I made sure only the Nehrim-files were marked, I unmarked the Oblivion.esm.
When I select 'Start Nehrim', this message shows up:
NehrimLauncher.exe cannot find the needed .exe file. You have to start the Launcher within the Nehrim directory.
Then I tried that, but with the same result.
Then I tried the 'Nehrim - At Fate's Edge'-desktop-icon which launched a game that appeared to be still Oblivion itself. I didn't understand: I deselected the Oblivion.esm (and I checked that with OBMM), I enabled the Nehrim-files, and when I start Nehrim, I get Oblivion?
I hope somebody can offer me some help, I would really like to get to playing this game :)
What folder did you install Nehrim into?
Re: Nehrim won't start
Post by Duzjah »
The path is 'C:\Users\UGent\Saved Games\Nehrim', so no Program Files since the FAQ advised not to install it there when you have Windows 7.
I am not sure whether C:\Users is good. Your problem is that Oblivion.exe is not in your Nehrim folder. The Nehrim installer is supposed to copy oblivion.exe from your Oblivion folder into your Nehrim folder. It failed. This means that either it could not locate the oblivion.exe in your Oblivion folder (because you manually moved around Oblivion?), or it could not read the Oblivion folder, or it could not write in your Nehrim folder. Try reinstalling everything (Oblivion, patch 1.2.0416, Nehrim, Patch 1.1.1.1), each time choosing a really neutral folder (no C:\Program Files, but no C:\Users either; something like C:\Games or C:\Bethesda).
Post by Duzjah »
I'll try that right after the weekend when I get back home,
but still... I guess that could fix my Launcher-problem, but could these action also fix my other problem?
Mmm...now that I've read your post again I guess it might, I'll try as soon as I can.
Post by Duzjah »
Awww... the same problem occurred. :(
But maybe there's something you need to know, I didn't install Oblivion on this computer, I did on my other one
and I just copied all the files in the C:\Program Files\BethesdaSoftworks-directory to this computer and well, Oblivion worked just fine :p
So I thought there was no problem there, but maybe there is?
So, what should I do now?
If you just copied your oblivion-directory from another pc, nehrim can't find the registry-keys it needs to locate your oblivion.exe.
To prevent more trouble, deinstall nehrim, delete all oblivion-related directories you copied and then properly install oblivion, patch it to the newest version and install nehrim to something like C:/Nehrim (don't use your user-folder!). Don't forget to update nehrim after you installed it.
The instructions I gave at http://www.sureai.net/forum/viewtopic.p ... ide#p39119 might also help.
Post by Duzjah »
Yeah, it works! :) Thanks for all the help.
I didn't re-install Oblivion, I just copied those files (Oblivion.exe etc.) into Nehrim and now it works just fine.
And I seems like it's going to be a good game too, the beginning is very exciting.
Nehrim won't start
Post by xliarsenickx »
I installed nehrim to my oblivion directory, which is under c:/...my games. and everything istalled right. then i manually installed the patch because i'm in iraq and i don't have my own 'personal' internet connection. then i did exactly what the read me said, untick all data files except the nehrim related ones. once i did this i started up nehrim, and it crashed. so i backed up my .INI file and let nehrim create a new one. then it worked. next problem....
i went to start a new game, and it asked me if i was sure? 0_o i clicked yes but it just took me back to the main menu. i tried this with space bar, the mouse, the joy pad controller. nothing worked. i can't start a new game. and also the mouse pointer isn't a mouse pointer. its just a big white box where the pointer should be.
im 99% sure i did everything right. i even backed up my saves to another folder to start fresh with nehrim saves. could someone please help me. i've been wanting to play this game for months...
