3 posts • Page 1 of 1
I have not patched yet, first of all.
Okay, So I probably screwed things up royally with this quest. Here is my huge problem.
The game has been great until I made my way down the Ayleid ruin backdoor to the Ostian temple to poison some guards. There is a glowing door with symbols and I'm supposed to "call friends" when I find this door. Well, Kim followed me down there with no problem; however, Callisto never appeared using the spell. I tried running back all the way outside and tried to summon him. He never came.
I walked down the hill to his first ruin spot, and he just stood there with a "I have no response" box over his head. So.....I did something bad here. I used the console to open the locked door and figured out how to steal the nightmare root ingredients after a long trial and error. When I poisoned the food, suddenly the game started working again and Callisto was there saying I had to flee out the Earth Worm way (which took me forever to figure out btw). I died a hundred times in that pool of green slime until I tried clicking on every root and object in there.
Anyhow, I made it down to Ostian. Yet, as I enter the harbor house in Ostian, Kim comes down from the stairs and reads a line that says something like we should call Callisto to help us open the door. This isn't so much a problem as the game has me locked in a "cinematic mode" where I have no movement or controls.
Is there a way to restore my controls?
And yes, I tried restarting from an earlier save and Callisto still fails to be summoned anywhere even if I stand next to him. I kind of wished that Callisto had gone through his ruin and met up with Kim and we all could have walked down the narrow mine shaft. That summon spell just never worked.
****Posted my save just before I go in the house and get stuck.
Ostian.zip
(1.24 MiB) Downloaded 251 times
You should definitely patch. We don't support unpatched versions.
Other than that, we would need a save from before the locked door that you cheat-unlocked, to figure out what the bug is from (most likely the problem will solve itself once you patch your game - but only if you load a save before you cheated!).
The patch fixed the issue. I cast the spell before going in the house, and then it disappeared from my spell inventory. Previously, it never left my inventory as I could cast it endlessly.
Sorry for the needless post.
