I'm afraid I broke the scripting for this mission by using the 'unlock' console cheat on the cellar door and journeying all the way to the Soul Train before realizing I needed the Star Map (thanks Wiki) and teleporting my way back to the Monastery.
Now when I have to do the quest for real, on the part by the 3 giant stone faces where you fall hundreds of metres down the pit, when I hit the bottom, instead of triggering the load screen I just fall through the bottom of the pit and the game engine puts me right back at the top and down I fall again, and on and on in this loop.
I even tried TCL-ing my way down the pit, but it doesn't work.
Do you have a console code that lets me spawn in the relevant area, or is it game over for me ?
Also, is the game supposed to use the FFDSHOW AC3 codec for it's sound ? When I alt tab out, there can be upto 20 or more FFDSHOW AC3 icons in the taskbar. I've never seen a game use FFDSHOW - at least with the icons showing up.
Is there something I need to do to tell the game not to use it ? Or is it okay ?
So what I am looking for is (in order of preference)
1) A console command to reset the load trigger at the bottom of the pit.
2) The Form_ID Code for "Daromith Temple - part 1" (hopefully there's a console command to load a specific map - as there is in practically every FPS ever made).
3) A DestFormID - maybe I can teleport there ? (I have no idea if such a thing really exists)
Failing all of this, i'm going try TMM1-ing my map and see if there is a separate location for 'The fortress of Cahbaet' - which is where the Wiki says that the mission ends up.
Sorted. I Tmm 1'd and went to the Fortress directly
Hi
Do not know what causes it (do not remember actually), it used to happen when I played Oblivion on my last pc. Cannot remember if it was because I was using a hacked xp os at the time, so I either changed os or just turned ffdshow off to stop it.
