Hello,
I have some problem with Nehrim installation:
I installed a while ago a german version of the game. Then as the english version went out I wanted to install it in order to play in english.
I reinstalled oblivion some times, downloaded the english version of Nehrim and installed it, but no matter what I try, when I start the game it's all in german.
Only the menu is partially in english, the rest (dialogs and inventory for example) is in german.
Could anyone tell me how it is possible to change the language from german to english?
Hi!
Have you installed EVERYTHING as here :
http://nehrim.wikia.com/wiki/Step-by-st ... tion_Guide
My friend had similar problem, and as I remember, he had forgotten something in the Istallation.
Thanks for your answer,
I read the guide you indicated, and finally found why it was in german
I actually just needed to check the NehrimEnglish.esp data file, which was the only one unchecked.
It works fine now, I'm wondering why I never looked into data files ^^
Thanks a lot for your help!
