After finding the Soul Fleyer and teleporting us to the monastery, Arantheal killed several soldiers on the bridge leading to the monastery. Few of them were left, so I killed them. Afterwards he just continues to run around, away from monastery and into the rocks in the stables area. This basicaly brakes the main quest, since the drawbridge stays rased and I can't get Arantheal to Calisto. I have reloaded several times with the same result. I wonder if someone had the same problem and if there is some solution to it.
I have the same problem only that Arantheal runs to the drawbridge but it doesn't lower.
I've tried tcl'ing to the other side and opening it but that doesn't work.
Is there a way to open the drawbridge via console or even if I tcl to the other side I can "teleport Arantheal to me?
Try going to the drawbridge before Arantheal, for me it just lowered when I got near it, perhaps its a bug? Seems odd that both of you have that problem. @Arjento, if you open nehrim in the cs you can find Arantheal's ID and use the player.placeatme command to tp him to you. I'm NOT SURE whether it works though, if you have to create a new Arantheal npc you might want to find the remove npc command as well to not get 2 arantheal's in game, which would be quite weird.
Can I have your savegames for analyzing?
Normally I would suspect that some of the chancellor's troops are not dead yet, but this has mostly already been fixed in one of the patches.
Arjento, I think it should work, because I had similar problem with New Vegas. There was a command to "teleport" NPC to the player, and that game is based on Oblivion engine.
Daniel, I have tried to run in front of him, but the drawbridge didn't lower.
arvisrend, I would be more than happy to send you my savegame, just tell me how. By the way, I thought that I found the solution. There was one soldier left, on the rocks behind us (when we got teleported) so I didn't see him. I killed him, but that didn't change anything. I used "tcl" command to scout around to see if there were more soldiers stuck , but I didn't found any. There may be more of them, on the road or somewhere else and that could be the reason why the script didn't work. I've had several similar situations, where enemies, running toward me, changed their path and wondered into woods, getting stuck somewhere or killed by animals.
Reply to this post, and while you are replying, click the "Dateianhang hochladen" tab under the submit button. This shoudl allow you to attach something.
arvisrend I send you my savegame. It was made after teleporting to monastery and before the fight with soldiers.
Save 106 - Aeron Olerian - Dividing Clefts, Level 35, Playing Time 127.15.35.ess
(4.08 MiB) Downloaded 253 times
Thanks. It seems you have tried to break the siege on your own? Because one of the soldiers is running against a rock way behind the stables, and there is one more missing. I am going to relocate them by script.
This patch should be of help. But you need a save from the Soul Flayer Temple, before the teleport to the Monatery.
arvis1109.esp
(12.49 KiB) Downloaded 261 times
Thank you, arvisrend. I've teleported to the monastery once during the siege, but after seeing enemies I have reloaded earlier save.
By the way, .esp file should go to the Nehrim installation folder?
