4 posts • Page 1 of 1
Can't start up..
Post by Shippage »
When I try to start up Nehrim from the shortcut created on my desktop I get the following error: "Application load error 5:00000065434"
When I run the Launcher from the install directory (not as administrator) it opens the launcher, I press Start Nehrim and it goes to the same error as above.
I launch Nehrim via Steam and the Launcher opens and I get the following error: "The Elder Scrolls IV: Oblivion failed to start (error code 53)."
Things I have done:
  • Ran the launcher in administrator.
  • Tried to install NetFramework2.0, could not because I am running 64 bit.
  • Updated Nehrim Launcher EN.
  • Ran Registry fixer in CCleaner.
  • Disabled everything else in Data files except for the Nehrim content. (I just re-checked and for some reason now ONLY the Nehrim data files appear where before all of my oblivion addons appeared there.
  • Restarted my computer.
I am running Windows 7 Home Edition 64 bit.
Someone help me please?
I bought Oblivion over Steam if it matters.
There is a different installation guide in the readme for Oblivion over Steam, did you follow those instructions?
Re: Can't start up..
Post by Shippage »
I just now did that, I did it kind of strangely though, not sure if you're supposed to install it this way but I renamed my original Oblivion folder to Oblivion(2) and then installed Nehrim at the spot where Oblivion was before in my steamapps folder and then renamed Oblivion(2) to just oblivion and had the folders combine, not replacing anything but instead renaming to (2) (For example credits(2).txt). It seems to run okay so I guess it's installed correctly? I can't launch the game over the Nehrim Launcher but instead using the Oblivion Launcher.
Not sure why the Nehrim Launcher wont work, but if you can start the Game via the Oblivion Launcher, you at least can start playing while we figure out whats wrong with the Launcher.
