I've been playing this for a couple of hours, and the only problem I've had (besides one random CTD on loading out of the mine), is that there are these sort of sheets that go randomly across the world. I can go right through them, but they block my vision. It's extremely annoying and immersion breaking. I've seen similar problems before in regular oblivion, but never to this extent. These sheets, for lack of a better word, seem to be at some height above the ground at almost every point in the game I've reached so far. On some sides I can see directly through them, but from others I cannot. Usually they block vision from above, but can be seen through from below (leading me to believe that they are some sort of misplaced ground mesh/texture, as I know from occasional glitches and playing around with the console that the ground is see-through from below).
I am running with a couple of performance enhancing mesh modifiers, including:
Oblivion polygone overhaul
Optimised distant land
Operation optimization
I doubt distant land is the culprit, as these are all over the place. Since these are mesh modifiers and not ESPs, I can't easily turn them off to fix this if they are causing the problem.
Is this problem a known glitch in Nehrim? Or is it just something I've encountered? If it's just me, how would I remove these mods from my game? I don't have a copy of the original game meshes on my computer. Any help would be greatly appreciated.
Oblivion polygone overhaul is broken (reproducable crashes in a mainquest-relevant place), but I'm not sure whether this is the culprit. Optimised distant land could be it as well.
In order to uninstall them, try installing them into a new directory (rather than into your Nehrim one), and look which files they have created. Try to delete exactly the same files from your Nehrim directory. But be careful - actually, move the files away, don't delete them. If all else fails, do a clean reinstall of Oblivion.
