Hi, just downloaded Nehrim a few days ago and have been enjoying it so far but I've been having some issues with FPS despite having a fairly powerful PC.
My specs are:
AMD Phenom II 965 Quad-3.4GhZ
ATI Radeon 5850
6GB Ram
Windows 7 64-bit
Indoors my FPS seems to be fine and stays around 60 FPS (v-sync enabled) with no real issues even during combat. Outdoors is a completely different issue. Depending on where I am my FPS is generally anywhere from 15-40 though generally lower especially during combat/if I'm riding my donkey (yeah, I'm a newb). In combat in an average wooded area near the start of the game I'll generally drop to ~20 FPS and sometimes a bit lower. Also while I'm running around sometimes the game will randomly get a bit choppy or freeze for a second or two and its pretty annoying.
Earlier I reached Stonefield and found the worst constant FPS I've had so far, its hardly playable at this point.
http://www.xfire.com/profile/moarxx/scr ... #106914628
My current settings in-game are:
1600x900
4x Antialiasing
V. Sync enabled
View Distance: 100
Distant Landscapes, Buildings, and Trees Enabled
Tree detail: 85
Actor visibility range: 20
Item visibility range: 23
Object visibility range: 29
Grass visibility range: 34
Interior shadow visibility range: 50
Exterior shadow visibility range: 30
Self shadow: off
Grass shadow: off
Canopy shadow: on
Shadow quality: high
Specular lighting: 100
HDR: Off
Bloom: On
Water detail: high
Water reflection: on
Water displace: on
Window reflection: on
I've tried messing with some of the settings but nothing has had a very big impact (disabled shadows entirely, turned off distant trees, etc.).
I don't have an exterior mods for Oblivion/Nehrim, just the latest patches for both.
Also I feel like I should mention that a few months ago I tried modding my Oblivion (I bought it off Steam a while ago and hadn't played it) but got frustrated after a while due to ending up with mediocre framerates. At the time I had the following (and possibly a few other mods) installed:
Unofficial Oblivion Patch
FCOM
COBL
Qarl's Texture Pack
Natural Environments
Unique Landscapes (all)
Any help would be appreciated, hopefully this doesn't come down to Gamebryo being horribly optimized for my hardware
My specs are:
ATI Radeon 5850
6GB Ram
Windows 7 64-bit
1600x900
4x Antialiasing
V. Sync enabled
View Distance: 100
Tree detail: 85
Self shadow: off
Grass shadow: off
Canopy shadow: on
HDR: Off
Bloom: On
Water detail: high
Water displace: on
FCOM
COBL
Qarl's Texture Pack
Turning off anti-aliasing in Stonefield doesn't seem to increase my FPS at all, its still 11-16 when standing in the square watching the 2 soldiers fight.
I really have no idea of what's causing this.
Maybe you could try some of the advanced options you can choose within the Nehrim launcher.
I'm using the Steam version of Oblivion so I'm forced to launch it through Steam (and the Oblivion launcher). Will changes made in NehrimLauncher.exe (even though it can't actually launch the game) still effect the game?
Went ahead and tried it anyways, the first time I changed the settings and hit accept followed by "Start Nehrim" which just took me to an Oblivion launcher with faded out buttons. Upon launching the game via Steam it tried autoadjusting my settings according to my PC and set me back to Very Low. Launched the game, fixed it all, went back into Nehrim Launcher settings but this time I hit Accept and then launched Oblivion via Steam.
I loaded my game in Stonefield (in the square watching the 2 guards fight) and now as opposed to the 14-15 FPS I'm getting 8-10.
I enabled Multithreading, Dual CPU using, HDD using, and 2GB Memory preload.
edit: Went back in and disabled Dual CPU using (since I have a quad core) and launched again, didn't notice any change in performance (multithreading still enabled).
After playing a bit more it seems as if my issue is related to outdoors npcs. My fps is fine in dungeons with multiple npcs (bats+Bone flayers for example) but my fps drops quite a bit when fighting mutiple npcs outdoors. Same goes with npcs in towns, the bigger the town, the more my fps drops. My actor view range is set fairly low and I tried disabling npc shadows but neither seemed to fix it.
Do you have onboard sound? That might be the issue.
Unfortunately, yes. I'm just using whatever comes on a Gigabyte GA-MA770T-UD3P though I am using a USB headset (http://www.newegg.com/Product/Product.a ... sair%20hs1).
I'm fairly sure that the drivers are updated, just updated those a month or so ago. Though I've been advised by a few people to possibly try the default W7 drivers since the Realtek ones have given me issues in the past (hence why I'm using a USB headset).
edit: Link to the motherboard - http://www.newegg.com/Product/Product.a ... 6813128392
Onboard audio is Realtek ALC888
Onboard audio is not a matter of outdated drivers; it's a matter of suck.
The only way to kill those lags is to use a "quiet feet" mod, which stops the sounds of NPC's/creature's feet from playing. It's these sounds that cause many lags in battle. There is a quiet feet mod for Nehrim, although I don't remember where. As an alternative quick solution you could also pull the "Effect sounds" down to 0 in your settings.
I'll try that out, I was thinking of doing it but figured it wasn't the issue since my FPS is fine indoors.
edit: Just tried turning footstep volume and effect volume down to 0 and didn't notice any increase in performance. Still getting <20 FPS just standing around in Giliad. Also cannot seem to find the Nehrim version of quiet feet.
Have you installed Nehrim over a clean Oblivion or over a modded Oblivion? Because if you had Qarl's texture pack, maybe you still have it in Nehrim. And it does increase hardware hunger.
It was a clean install via Steam.
Ran the Nehrim exe and saved it into a folder on my desktop then moved all the files inside to the Oblivion folder.
Any other ideas? :/
You have decent hardware except for sound. So why not get a good sound card to complete your system? You should not expect to get good game performance if you are using on-board sound.
Also, I would look at every single process and service that is running and eliminate anything not required to run the game.
I'm highly doubting the reason behind me getting <10 fps in a relatively small "city" is because I'm using onboard sound but I am looking into buying a decent sound card. It more likely has to do with Oblivion not being too kind to any newer hardware (from what I've seen) though what I've been trying hasn't seemed to fix it (enabling Multithreading under the Nehrim launcher actually LOWERED my fps?). When I had Oblivion modded I got ~20 FPS in the main city's trade district while raining (with a good weather mod installed). In Nehrim I get 9 fps in a town during clear weather.
Also, I practically always do that and hardly run anything in the background normally. Pidgin and Steam, maybe Ventrilo, none of which have any real impact on my performance.
What I need to figure out is why NPCs have such a huge impact on my performance while outdoors despite being fine in dungeons even when fighting 4-5 enemies at once.
Sorry, but I'm at my wits' end here. If you are inclined to do some experimenting, try putting down some settings like Exterior Shadows (Oblivion FAQ: "Set Exterior Shadows as low as possible. This will decrease the number of characters that cast shadows while you are in exteriors, improving your framerate." - given that you have problems with NPCs). I do have framerates around 15 in Erothin too, but I'm playing on a laptop, and I have most settings much higher than you (except of a smaller screen res, and no antialiasing - I never use AA), and pretty much everything except for Erothin runs rather nicely. Sorry, maybe it is really your hardware...
Might as well ask a few questions about your configuration if you don't mind.
Are you using the Steam or retail version of Oblivion? I could pick up the retail version very cheaply (without DLC) though I'm doubting that will have any real impact unless the Nehrim launcher settings aren't working correctly with Oblivion from Steam.
Have you changed many .ini settings for better performance? The only thing I've really done is install the 4GB patch, I'm going to try messing with other various settings in a bit.
edit: Changed around the Cell buffer+preload settings and didn't notice an increase in performance.
If you were to allow your Oblivion to auto-detect hardware, what does it try to put your settings at? Despite mine seeing that I have a Radeon 5800 series it sets my settings to Very Low. I just tried running Oblivion with these settings and despite it looking absolutely horrible (as you can imagine) I'm still getting under 60 FPS in Giliad. Depending on where I look at I'm getting 40-50 FPS, sometimes 55, never over 60.
Also, I'm not even sure it is an issue with NPCs outdoors, I'm just guessing at this point. Overall my performance outdoors is mediocre but becomes worse in small towns like Giliad (or nearly unplayable in parts of Stonefield). I just turned off ALL sound and shadows and noticed maybe an increase of 3-4 FPS at what I was currently looking at (a guard with a forge behind him in Giliad). I move over to the bulletin board and stare directly at it (I can hardly see anything else aside from the board itself) and I'm getting 18-19 FPS steadily. Looking at what was basically a wall.
edit: For now I'm going to try reinstalling Oblivion and running it vanilla to see if my FPS is still bad, will back up my saves though and plan to reinstall Nehrim if I can figure something out.
I've also found turning off distance land lods (TLL) will often help.
Hi.
Sounds like you might run fraps a lot ?
Tip. Might help. Turn it off.
If you have a save game in one of these areas, check it out with fraps on. Turn off fraps and instead use tdt at the consul. Watch fps in top right as you run through your test area.
It cannot give min/max or avg's but you should see a difference.
@scooby
I'll look into that, not sure if I have that on or not.
@Hawk
I don't have fraps installed nor have I ever downloaded it.
Haven't bothered uninstalling Nehrim/reinstalling Oblivion yet, been kind of busy lately.
@Hawk
