So I have 2 of the stones. The one from Treomar and the other from the North area. When I got the first stone, the quest log erroneously updated my quest to say I have all 3 stones, so I basically had to find the other one on my own, and I finally found the glider to get the 3rd the other night. I CAN'T USE THE GLIDER! Is there a way to fix this?
Wanted! I killed the Death Fairy and the thing that spawned after she died. I've updated to the latest version of Nehrim and have made sure it's the correct version through the launcher, v.1.0.82 or whatever. I've tried all the console commands that have been suggested here, yet it STILL doesn't work! ARGGGGGGGGGH
1 Other thing, where in the heck is the arena in Ostian? I can't find that either and I've been all over Ostian.
Please help me!
(I have the Steam version)
Please help me!
Why can't you use the glider? (Upload your save please).
The problem with the Death Fairy is that you have "completed" the quest BEFORE you updated, right? Try typing "set nqwanted01.justone to 1" into the console.
The Arena... I recall it is next to the Malogos mage shop but I'm not sure. Try looking for it on your local map.
Found it
Save 405 - Loki - The Kettle Mountains, Level 32, Playing Time 105.59.09.ess
(4.27 MiB) Downloaded 222 times
Found my save file, it's up above there.
I think you should not just pick up the tablet but also take (or at least read) a book/diary/excavation report.
I did find the excavation report and book, read them, turned them in to Gevarius (or whatever his name is). I've done everything in that quest and got a faulty update on it that said I had the 3 stones when I only had 1 and now I can't use the Glider to actually get the third stone. So when I do go back to Gevarius, even though it says I have all three stones, he knows that I don't have them all in reality.
In that case, your savegame isn't helpful, as it doesn't have all of these quest notices.
