3 posts • Page 1 of 1
Starting with the Dredfire Staff, it comes with support for both Oblivion and Nehrim. Though it is, technically, in English, it should work fine for any language version.
Dredfire Dragon Staff
By Gizmodian
Description:
A single staff using the GothResourceSet Dragon to make the Dredfire staff. Support for both Oblivion and Nehrim available.
Installation:
Either manually install by unzipping directly into your Oblivion/Data folder. If prompted to overwrite, select 'yes'.
Or make it into an OMOD using OBMM.
There are instructions in many places on the internet on how this is accomplished.
NOTE: Now, there are two esps in the folder. One labeled NEH for Nehrim, the other labeled OB for Oblivion. **USE ONLY ONE.**
In Nehrim, it is located in the Erothin Tavern in the back. Remember the staff IS on fire... it's sort of hard to miss.
In Oblivion, it's in the Arcane University grounds, top of the stairs.
Uninstallation:
Delete the files or remove the OMOD.
Additional Info:
The textures packaged in the mod is normal size, which is a 1024px square.
If you want high-resolution 2048px, download the GothicResourceSet and overwrite the texture directory with the one packaged in the 2048's folder. It will double the texture size, and give you better visual clarity, however, it may impact performance.
Programs Used:
3DSmax9
Adobe Photoshop CS3
Nifskope
Credits:
Bethesda
Blackheart for the fire setup.
Jexsam for making the Oblivion compatible esp as well as the in game screenshots.
Usage and Permissions:
This is an open-source resource, you cannot claim it as your own. You may use any part of the meshes or textures, however, you must credit me.
Dredfire Staff at TESNexus
Thanks to DarkRuler2500 for German version of Dredfire.
Dredfire-Staff_DV at TESNexus
Blade Set 01
By Gizmodian
Description:
A set of five new blades and one offhand. One claymore, two longblades, one dagger,and a drow-style punch blade with matching offhand.
Installation:
The default mod contains 1024 size textures. There is an alternate folder marked with the 2048 sized textures, however. These double the size and are much higher resolution, giving you a better looking sword. If you wish to use these instead, install the 'textures' folder underneath your 'Data' folder, after you install the mod. Select 'yes' when prompted to overwrite.
***THERE ARE TWO ESPS IN THE ARCHIVE. ONE LABELED NEH FOR NEHRIM. THE OTHER OB FOR OBLIVION. +USE ONLY ONE OF THEM+.
NEHRIM: Found in the Erothin Tavern along the rightside wall as you walk into the door, near the stairs. Found in a small chest on the counter. It can be missed, so look near the shelves.
OBLIVION: Arcane University grounds in a chest on the circular wall. Can't miss it.
Uninstallation:
Additional Info:
The textures come in two sizes, normal, which is a 1024px square, and high-resolution, which is 2048. Double the size. It will impact lower computers, but the visual clarity is much better.
Programs Used:
3DSmax9
Adobe Photoshop CS3
Nifskope
Credits:
Bethesda
Jexsam
CLICK FOR DOWNLOAD AT TESNEXUS
