I was in the middle of doing "The Robbers' Nest" quest with Handor, but decided to do the "Into The Forsaken Country" quest.
The problem is though when I escaped the prison, Handor is gone! And I can't complete "The Robbers' Nest" too.
How can I fix this?
Can I respawn him via console?
Thanks.
How can I fix this?
Thanks.
I don't have an earlier save for his player ID.
Can anyone oblige?
Thanks.
Can anyone oblige?
Thanks.
Handor's Base ID is "001FDFC6". To add him, open the console (~ button), type "Player.PlaceAtMe 001FDFC6 1", and press enter.
However, depending on where you were in the quest, I'm not sure whether this will actually enable you to finish it. Have Handor and his troops already started running towards the bandits' hideout? If so, is he the only one missing, or are the other members of his troop gone as well? Some of the other soldiers are important to the quest. It might be worth checking in the woods near the hideout to see if they're hanging around there, waiting for you to approach and trigger the next quest stage (I think they'd be to the south or southeast of it).
Also, you should go ahead and make an extra save before trying anything. If it turns out to be a bug, arvisrend will most likely want a copy of your save to look at.
Respawning is not the way to go - you need the right reference, not just the right object.
Try
player.moveto 1FE0BB
and then tell us where you have landed.
Try
Thanks!
The placeatme worked!
Also when I done moveto it took me to the begining of the otherworld and guess who got left behind...HANDOR! I missed you so much!
