So, Nehrim worked just fine for like 8 hours or so, but then suddenly the game crashed (black screen, asks if I want to send an error report) for the first time. After that the game started to crash constantly: if I go to the same place where the game started to crash, save the game (saving works fine and I'm still able to play) and then try to load it: the game crashes.
So the game has crashed only once when I actually play the game, but after that crash, saving (actually loading) won't work. Saving/loading works fine if I won't go anywhere near that place. After realizing that, I tried to move on, but I still met this same problem in certain places. AFAIK the problem isn't in those certain places, because I've tried to load an older save game (had played for a few hours and still was in the abbey), go straight to the place where the game started to crash, then save and try to load it = no crash.
Here's a save: RapidShare / Megaupload
For example, go somewhere near Handor the Axe Swinger (map image: http://oi56.tinypic.com/27yrfgg.jpg), save the game and try to load it. If someone could try that out in order to know if my save is corrupted or is it my computer. I've just reformatted my hard drive, so there can't be any viruses or anything, I guess.
Specs:
Windows XP
Intel Core2 Duo CPU E6850 @ 3.00GHz
2048MB RAM
GeForce 8800 GT
Specs:
Windows XP
2048MB RAM
GeForce 8800 GT
I just tried your save file and I got the same crashing problem you have when I tried to load the save file I created at the paticular place on the map. I actually tried more than 5 times but every time it crashed or froze the game completely. Unfortunately I think your save file is corrupt in some way. You should probably go back to your older save file before you had blackscreen crash and restart from there. From my experience all auto-saving feature should be turned off(including the one in diary)which helped me a lot.
Which Oblivion version do you have?
summers wrote:I just tried your save file and I got the same crashing problem you have when I tried to load the save file I created at the paticular place on the map. I actually tried more than 5 times but every time it crashed or froze the game completely. Unfortunately I think your save file is corrupt in some way. You should probably go back to your older save file before you had blackscreen crash and restart from there. From my experience all auto-saving feature should be turned off(including the one in diary)which helped me a lot.
Chasm wrote:Which Oblivion version do you have?
Before installing Nehrim I installed the latest Oblivion patch (v1.2.0416) then I installed Nehrim and then the latest Nehrim patch (1.0.8.1).
