Name: Toggle Zoom with Any Key
Version: 0.4.0
Date: 24 X 2010
Category: Gameplay Effects and Changes
Requirements: Oblivion 1.2.0.416, OBSE 0018
Author: Androktone
Source: http://www.tesnexus.com/downloads/file.php?id=35144
Changes
0.4.0
-- fixed (I hope) issues with mouse sensitivity;
-- added the field of view factor, configurable in the INI file;
-- added the StayInZoom option, configurable in the INI file.
0.3.7
-- max. 5 levels of zoom;
-- number of levels selectable in-game;
-- added no-zoom key;
-- added the mouse sensitivity factor, configurable in the INI file.
0.3.0
-- 2 levels of zoom.
0.2.0
-- added an INI file.
0.1.0
-- initial, non-configurable version -- one should begin somewhere;
-- only 1 level of zoom.
Preface
Based on Troybayliss' "Toggle Zoom".
Description
Toggle Zoom with Any Key adds a zoom in/out function to keys of your choosing
(default: PAGE DOWN for zooming in and PAGE UP for zooming out).
There are 1 to 5 levels of zoom. Also, there is a no zoom key (default: SPACE).
Now saving a game while in zoom mode you can choose whether the zoom state
will be preserved or not -- see the StayInZoom option in the INI file.
Install and configuration
If you have an older version of the mod go to 1. Otherwise go to 3.
1. Delete the files "ToggleZoomAnyKey.esp" and "TZAK.ini".
2. [Perhaps unnecessary] Load a game, save to a new file, quit.
3. Extract the files to: %Path_to_Nehrim_or_Oblivion%\Data\
4. Configure the mod by editing the file "TZAK.ini" -- instructions inside
that file.
5. Start Nehrim (or Oblivion) Launcher or OBMM and check
"AK-ToggleZoomAnyKey.esp".
6. After loading a game, choose number of levels of zoom by pressing -- by
default -- LEFT SHIFT + 1/2/3/4/5, respectively.
Uninstall
Delete the files "AK-ToggleZoomAnyKey.esp", "TZAK.ini" and
"AK-ToggleZoomAnyKey.txt".
(In)Compatibility
I have no idea.
Tested with
Oblivion/SI 1.2.0.416
OBSE 0018 (0.0.18.6)
Nehrim EV 1.0.8.2
Known issues
This mod lower the sensitivity of your mouse when you are in zoom mode and
restore it when you zoom out. When you load a game the mouse sensitivity value
is registered. If you want to change mouse sensitivity, do it from the Main
Menu, before loading a game.
[I'm not sure it's still relevant, so just in case]
When you are forced out of zoom you are still in zoom mode, so your mouse
sensitivity will still be lower. To return to normal just use the no zoom key
(default: SPACE).
Credits
Thanks to Troybayliss' for "Toggle Zoom".
Licensing/Legal
Do whatever.
Version: 0.4.0
Date: 24 X 2010
Author: Androktone
Changes
0.4.0
0.3.7
0.3.0
0.2.0
0.1.0
Preface
Description
that file.
Uninstall
(In)Compatibility
I have no idea.
Tested with
Nehrim EV 1.0.8.2
Known issues
(default: SPACE).
Credits
Licensing/Legal
Do whatever.
[deleted]
