7 posts • Page 1 of 1
Nehrim Patch
Post by roxon_55 »
Running at Level 34, 41 Quest Completed,Have done 4 Quest since Running Patch over Game.
I use (R-Ctrl) as my block key, since i put pacth on I cannot use R-Ctrl it Disrobes Player + all weapons and Rings left stark naked. have shifted the block key still have problem, operator error i grab the wrong key have used the same keys for 3years playing oblivion.
Nehrim has NOT had any PROBLEMS or errors has RAN Flawless, I make less mistakes running under english 10+ GAME WELL DONE SUREAI.
wayne
Re: Nehrim Patch
Post by arvisrend »
We have not changed anything related to the keyboard controls or to blocking in the last patch.
Re: Nehrim Patch
Post by roxon_55 »
Thanks for Reply No Prob sufferd the key prob. Got through 58 quests completed over 100 hours Nehrim, done through to (My tenth fight is over. can buy new arena Armor) no Bounty left to do. How many (.esp) will work under Nehrim have got 40 to work so far, is the same as Oblivion. Is there any where i can send Pictures.
Thanks Again WELL DONE.
Wayne
Re: Nehrim Patch
Post by arvisrend »
You can submit an attachment using the "Dateianhang hochladen" tab under the Submit button.
Yes, the maximum number of ESPs possible is the same as for Oblivion.
So do you have the problem with the keys or not?
Re: Nehrim Patch
Post by roxon_55 »
Yes Prob with Keys still there Kept playing, player ends up naked every now and then does get her killed. Save to offten helps THANKS for help
Re: Nehrim Patch
Post by krathax »
Do you have the Stealth Overhaul mod installed? I know r-ctrl with that mod disrobes the player.
Krathax
Re: Nehrim Patch
Post by roxon_55 »
That prob solved YES i do have (stealth overhaul) installed.
New But not a prob, Installed Patch 1.0.8.2 Have mark & recall set at TREOMAR When you go to use RECALL it ask to Which Location. Dont have any other mark&recall running under Nehrim.
THANKS.
Wayne.
Level 39, Days in Game 51,completed Quests 61,41040 points till upgrade nothing respawns fastenough.
Has Not Failed Stil FlawLess.
