9 posts • Page 1 of 1
I'm in the part after you kill the guy inside the Coach, but I can't seem to get out. The door "Needs a Key", and apparently it's a part of the guy's "Strange Mechanism". I searched his body as well as pretty much every inch inside his house, and it just seems impossible to get out. Any help would be much appreciated ^^'
Thanks in advance!
Hi
I seem to remember.....
Look on the shield in smaller part of coach.
Kick me if I'm wrong.
I took 30mn to find the solution
You must look near his bed, and look up
Oh wow, thanks so much, shay! And thank you as well, Hawk, for trying at least xD I would never have found that, though.
So obvious, yet so hidden at the same time... thanks again! ^_^
I had the same confusion because of the nature of the quest. I automatically assumed the "mechanism" was the fire mine instead of
a separate one within the coach. The key also adds to the confusion. Perhaps remove the lock since it doesn't actually serve a purpose (the door is effectively double locked) and make it so that the door says something when used like "This door is locked by some other means. I should search for a release to open it."
The lock is there so that the player doesn't leave before killing Adrak.
I need help in this too... so when you have found the instructions, and you get a journal entry about going to a coach, I don't get it where I should go... I've been searching nearby for their camp, they mentioned in the instructions, but no help. I don't have a quest marker, should I?
the coach is in the showgrounds, very close to the chest on the road that started the quest
Thanks, I don't know why I didn't search from there, I just thought it was related to some other quest...
