6 posts • Page 1 of 1
First I want to say thank you to the team that brought us all this amazing mod, I can't put it down and it is enticing me to learn German even though the subtitles and book translations suffice.
My problem has to do with the location 'Zerobilon', a large tower on the Northern part of the continent. Without giving away anything to people that do not want it spoiled, I found the key and was able to go through the entire tower to it's end. I was thrown for a curve though. I will cover my questions with spoiler tags:
Question #1
Is the gate at the end operable? It says it is blocked and there appears to be a force field in front of it. I turn collision off and it still reported this. Searched the room for levers and switched...nothing.
Question #2
I looked through translated German topics on the site and found reference to this. I went to the 'Showground' and entered the wagon there. I read the notice, saying where to get the key to Zerobilon (that I had already found), as well as a switch in the form of a Coat of Arms on the wall and a lever above it that made both a secret door opening sound and magic sound respective. I looked everywhere...nothing opened or appeared and I turned off collision to again double check. No quest info popped up from reading the notice, did I mess something up by finding the key first and going to Zerobilon?
Any insight into Zerobilon would be greatly appreciated. Amazing place and I don't want to miss out or find out that I inadvertently messed something up. Thank you in advance for any help.
elderdrake wrote:
Question #1
Not implemented, yet.
Chasm wrote:
elderdrake wrote:
Question #1
Thank you for the quick reply.
elderdrake wrote:
Question #2
I'm fairly certain that you didn't miss anything.
The lever on the trailer's ceiling just allows you to open the trailer door after your battle with Adrak; the door locks behind you and even with his key you can't open it until you hit the lever. As for the coat of arms, it's listed as a static object in the CS. Are you sure you didn't just hit the lever again? It has a pretty large toggle area, and I remember that at first I thought I was activating the coat of arms, too.
And yeah, you didn't get a quest popup from the notice because you had already defeated Alcazar and taken her key, which completes the quest in which Adrak is involved; I wouldn't call it messing up, though. In fact, the writers made a slightly different message to account for the possibility that the player finds Alcazar before Adrak ("Within Alcazars throne room I found a key to Zerobilon, the ancient tower at Nehrim's north coast." instead of "The mines seem to come from Zerobilon, the ancient tower at Nehrim's north coast.")
haha, idont know if anyone is still watching this, but whatever. For Q2, you didnt miss anything.
You were supposed to go through the quest A Fiery Welcome, which starts with a chest in the middle of the road close to the showgrounds. It then goes to the coach, and you have to use those switches to get out of the coach. You then go to the place where you get the key, and then off to Zerobilon. Btw, the quest didnt really do anything besides maybe give a little EP.
That quest can still be done if you already have been at Zerobilon. You get a piece of armor from a low-level set, so it's not THAT useless. ;)
