10 posts • Page 1 of 1
Hi guys, its me again...
Im on the road from Mountain Monastery to Treomar Library (Treomar, Center Plaza). Two minutes later I stuck at Magicialy sealed Iron Gate. I need a key to open It (that was wrote on God Order from Erodan, He wrote that This gate must be close in magic way, so they could stop the invasion - or something like that:) ). But where I can find this key?? At gate I found only 2 skeletons and This Order :|. I Dont have any note in Journal - Where I should Start??
Hi
I wondered about this too, but if you just turn around, travel a bit down the path you came down then turn right (I believe), you will find an alternative yet longer route to Treomar. Also, be really careful, some of the mobs in Treomar are pretty deadly (when I was lvl 12), I wouldn't stay to chat.
Somewhere around the gate you should find the description that says "If the army wants to pass now, then they'll have to pass through the swamp" - with other words, that's where you should be going aswell. :D
The gate is perma-locked, but the long way around isn't all that long. :) Just use the other road (There should've been a fork in the road a little earlier. one going right to the gate. the other going left, to the swamp)
What can I say - swamp, Im coming!! (lvl 15 Pala with Uber Stuff;p).
Goodluck, it was quite hard for me to clear the dungeons at L20. I had decent stuff aswell. (Northern kings set)
At now I have lvl 17 and very nice items - my star is "Armagedon Blade", 2h sword witch drain strenght (at my lvl 48 dmg). I have 2 parts of "Prophet" set but i dont know where I can get other parts :/(I have crown and boots)...Anyone know other sets that are pretty good?
Avenzins ... (in german:Schlachtenhymnen) is also a good set. Another one is the northern king and finaly the (in german: Sternenbatalion) dwarven set.
This sets you will find in the whole world. In the mainquest you will find also a good set.
Hehe, I think the translation on Avenzin's is partially wrong. The set in english is called "Alessia's" whilst they are part of the set "Avenzin's" - and even one of the parts, Breastplate I believe, is named Avenzin's. While the other parts are named Alessia's.
damn, that sword is good:); im at level 30 now and i couldn't find a better one (with master armorer and 80 strength it has 117 dmg); i didnt find the other prophet parts untill now, sadly
Armagedon is the best sword/weapon. In the past it was stronger but they made it weaker with a patch.
There are only a few weapons which are a little bit weaker than Armagedon.
