Yeah... basically i can't find them, the slave tells me i should get them before we leave the fortress, but the only place i can't go is locked, and the key is no where to be found. so... help`? i can't continue playing unless i get my stuff back
You have a ways to go.
You haven't missed anything just keep going , you'll end up going outside and way down a path and you have to fight the Druid and then walk all the way back inside the prison and open the other door, then you get your stuff eventually. {it takes a WHILE}
>___> then why does the slave say that i should get my gear before we leave? kinda seam to imply "your stuff is in here, if we go out now you will loose it, so make sure you got it"
oh well, better gear up with them iron shortswords for a while
