4 posts • Page 1 of 1
OK so somehow the distant blur effect on the Distant LOD you have in Nehrim has disappeared, and it looks the same as in oblivion. I don't know what possibly could have made that happen. I was messing around with the Textures folders abit though, because some textures were pink when playing Nehrim. I solved that issue with copying the Textures folder from my Oblivion\Data to Nehrim\Data. But since then the distant blur hasn't worked. Can you try to wrap me around this? thanks.
uhm... just reinstall nehrim, your save files should be unaffected as they are in your documents folder... back them up if you need to be sure.
No need to reinstall. You can go to your inventory and click on your diary. There, you'll find a few options to fine-tune some of the game's graphics-settings. One of these is the Depth of View setting, which generates the blur.
actually i sovled the problem with just turning the Distant Land in the Video Options on and then off and turning anti-aliasing off
