5 posts • Page 1 of 1
The installer only installs Nehrim files, it doesn't create a copy of the Oblivion files. The Oblivion directory is in the right place, why isn't it creating a copy? What can I do?
I think thats the issue, when I click play on the launcher it says it can't find the appropriate .exe file.
Maybe UAC prevents the installer from accessing your Oblivion folder? Or you have moved the Oblivion folder without replacing the registry entry?
In such cases a re-installation of Oblivion will help.
But only when you are installing Nehrim into a directory that is not protected by UAC. ;)
