12 posts • Page 1 of 2
Where can I find my stuff
in the dungeon after I am saved by Kim?
It feels like I've looked everywhere.
Edit:
Figured it out. I thought I was supposed to find it before leaving the dungeon.
Yeah, I had the same problem - the quest log makes it sound as if you should find your stuff before you leave the building. It could do with a slight edit. I tried every container, then searched for secret panels etc etc. Spent at least half an hour running round before I saw your post and thought 'ah, okay then, let's just see...'
So cheers : )
I'm having trouble as well (after obtaining my stuff).
When I move the crates and enter the secret tunnel, the exit to the tunnel requires a key, which I can't find anywhere. Where is it?
Hopefully you can answer since you've done the quest.
They key should have been on top of the crate which contains your stuff.
Thanks! It had fallen to the side of the crate and I missed it completely.
Ah, thanks for the hints. I thought I'd stumbled onto a bug there.
how far down the path should I go? Still missing it :)
Where is my stuff located on The Path of the Gifted Quest? I've looked everywhere and I am even outside in the snow with Kim, and I still can't find my stuff. Nor could I find the key to the locked door at the other end of the hallway.
What I am missing here?
it's been far too long since i've done this quest. so i'm not sure how good my info is. and i can't remember the path all that well.
i think you need to find a mage, living in front of a cave on a hill (or something like that). he has the key you need. his camp is mentioned in a note in a nearby bandit camp i think... you need to follow that path that goes over the frozen lake... i hope?
i hope that's more useful than i think it is. could someone please give this person better directions.
I found my stuff! :D Oddly enough, I couldn't find the key to gate. I to use the console to unlock. I don't care of that counted as cheating, I seriously couldn't find the key.
