4 posts • Page 1 of 1
Mana regenaration rate
Post by maxst »
Hi everyone!
What is the default mana-regen rate for Halb-Kilene level 1?
% of max mana per second
Hello maxst
The magic score and regeneration rate are actually the same for everyone, unless you have activated a race bonus in the magic menu that affects them.
I don't know the exact values at the moment, especially since it also depends on what bonuses and abilities you have
and whether you are currently in combat or not.
25.07.2025 18:28Stefanie wrote:
Hello maxst
Thanks. I mean the "clean" state, without any bonuses, gear and out of combat.
Using command `player.getav magickarate` I get 3.00, which means 3% of max mana. This is consistent with Skyrim.
However, manual calculations with timers led me to the 0.3% of max mana. So, more precisely, I wonder whether actual default mana regen rate should be near 0.3% or 3%?
As I said, I don't know the exact values myself, but they are identical without bonuses or spells,
however, they differ depending on whether you are currently in combat or not, for example.
