Bug appeared at the moment when I ariived to Arktwend, remained at the island and now after prison in Erothin. Game become unplayable - please help.
Have you tested whether the problem also occurs with older saves? In other words, before the bug occurred for the first time.
Otherwise try the following console command (save manually beforehand): set timescale to 10
20.04.2025 13:02Kermit 61 wrote: Have you tested whether the problem also occurs with older saves? In other words, before the bug occurred for the first time.
As for using console - after set timescale to 10 game becoming completely unplayable, because of heavy graphic glitches. Thaks for your willing to help, but it isn't a sollution.
Can you send us a saved game of the boat (directly on arrival) for testing purposes, + a save with the error and an even older one?
Game saves always consist of an ess and an same named obse file, for compatibility with the forum, put these 6 files in a zip archive
and upload it here as a file attachment. I can't promise you anything, but I would take a look at the save and try a few things out.
PS: have you integrated any mods? (we always test without)
21.04.2025 11:27Stefanie wrote: Can you send us a saved game of the boat (directly on arrival) for testing purposes, + a save with the error and an even older one?
What was suspicious the last time when the bug with time appears? When we arrived to Arktwend I was unable to move, so I used playerenablecontrols (or something like that) console command and bug appeared. May it be linked one with other? And another thing - we spend more time on the road and there was day 31 when we go asleep. May be problems with month change?
I'm sorry, but I havent saves from the last time, when i was locked in a boat and when the bug with time appeared.
P.S. I didn't intergrated any more mods. I'm using last available version of Oblivion from GOG.COM and last available version of Nehrim from GOG.COM. Nothing more.
P.P.S. I still have the savegame after breaking from prison in Erothim with time goes like crazy. If it's needed I may give them to you.
Ok, it's a bit of a shame that you no longer have your old saves, but if you can get on with it another way, that's ok and I consider it solved for now.
There won't be any more patches for it anyway.
cheats of any kind can destroy the saved game at the wrong time or in the wrong place, which is always bad, unless we test it in advance,
AND you have a separate manual save beforehand.
Yes, the command mentioned can trigger something like this because scripts in the background are blocked or changed.
PS: Savesgames after cheats falsify any further testing, so are less useful to us.
